Question about Microsoft HP Pavilion DV6276US Notebook PC
Volume bar won't go away
Sometimes after I use the quick/touch volume buttons a big volume bar pops up in the middle of the screen, and i can't make it go away unless i exit the program or close my laptop. That's just to much of a pain how do I get this Volume bar go away.
  • Anonymous Feb 11, 2009
    This is a problem I have as well, it's absolutely ridicules. Sometimes it'll even go away after a few moments, only to come back the moment I move my mouse or the laptop itself.
Went to hp and talked to a support person who gave me this driver update: ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe.. visit their website this is a pretty common probem....
Posted on Nov 26, 2008
  • diane_peanie Jan 27, 2011
    THIS WORKS!!!!! THANK YOU SO MUCH. Copy and paste but don't put the periods after exe, which I did at first. This is from Hewlett Packard, so it is safe.
  • tocinathan
    tocinathan Apr 24, 2012
    What happens/how should I proceed once the driver downloads?
  • 3 Answers
Been dealing with this annoying problem for months. ftp site submitted by iryan74 was absolute solution. Volume bar no longer appears to disrupt my use of compter. THANK YOU!!
FYI - The link above in iryan74's paragraph needs to be copied and pasted in the browser bar. Clicking on the link does not work.
Posted on Dec 28, 2008
I have the same problem and did a little looking around. I found a way to avoid the problem not to fix it. I have a dv9933cl with Vista (64bit). Go the the search bar under the menu and search 'msconfig'. Under one of the tabs on the screen that appears after clicking 'Open msconfig' there will be a list of checked items. One of the items is named 'Quick Touch On Screen Display' deselect this item. Click 'Ok'. It should then prompt you to restart your computer. Do so. Your volume Touch Sensitive keys should now work properly with any application open but you will not get a display to show you the current volume level. If anyone finds futher infor please let me know. Hope this helps.
Posted on Dec 19, 2008
  • 76 Answers
It's in the audio settings under control panel
Posted on Nov 21, 2008
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
Volume control won't go away. Windows 8
right click on it, click settings and turn off start automatically. then right click on it again and click close.. Its a service that comes with the software, there are other ways to disable it but that's the simplistic one..
Dec 27, 2012 | Lenovo Computers & Internet
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
How do you turn up the volume on the Tom Tom. Sometimes when I run my finger across the bottom it shows the volume but now I can't get it to show up.
Generally it should be on the bottom left hand corner. It you touch the area where "no route planned " is shown, the volume bar pops out. If this is not happening, follow this procedure. Tap on : the main screen. Tap on : Change preferences. If the sound is turned off, you will see a green button that says turn on sound. Tap on it. Else Tap on : Arrow. Tap on : Volume preferences. It shows an info screen. Jjust tap on it. On the next page that opens, increase the volume. Also select link volume to car speed as it is a good option. Tap on : test Tap on : Done.
May 12, 2010 | Tomtom ONE GPS Receiver
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Problem
I understand that when you try to increase the volume the programs freezes.
To isolate the issue please uninstall HP Quick Touch Software.
Here are the steps to uninstall HP Quick Touch Software.
Click start and select Control Panel
Then select Programs
Then select Programs and Features.
This will show list of programs
There select HP Quick Touch Software and click on uninstall/Remove.
Then restart the Notebook . This should resolve the issue.
Thanks.
Aug 21, 2008 | HP Pavilion dv9000z Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
6,544 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
