Nintendo DS Console Logo
ROYCE MASTERSON Posted on Nov 21, 2008
WIRELESS MICHROPHONE WII
Hi,i purchased a wireless michrophone for a wii games consul,both syncronised but no sound,please can you help.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
220
Points
Hello royce_master,
It sounds like the problem you are having problems with the Motherboard, the wires are probably ripped up a little bit, trade it for a new one and it will work fine. Also check your Wii Settings.
Hope this Helped - NeWeVoLuTioN
Trying to play nintendo on line. have a new wireless router/modem it is giving an error code of 52230 and says unable to connectg to server. any ideas?
Your nintendo consule without a technical malfunction should integrate to a network. The wii fii feature allows to network by wireless recognition of another consule on the network. The situation requires finding another consule owner to network with. Both consules would communicate by wii fii signals, only require recognising another consule owner that would allow device to device connectivity. keep in mind that, the error message is a computer message indicating a break in the link that could be created once another consule is recognised.
The error message would be intergrated into a network hub once each owner of the consule enable a feature on their device to accept communcation.
The wii fii feature only is advantage to the consule owner compared to connectivity that would have been performed by connection cables earlier in the invention of video gaming.
Advice
Find colleages with similar devices, inform them about wanting gaming network connectivity to allow possible network. keep in mind that, networking is a connection involvign entities where people are a requirement..
Your situation would be possible by human networking to make possible, device to device; that would only communicate when enabled features disabled.
2answers
How do i get wii shop chanel
Hello
To get to wii shop channel first you need to configure your system
Configure your Nintendo Wii for a wireless Internet connection. The only way to access the Wii Shop is by having an Internet connection and a wireless router. The Nintendo Wii has a built-in wireless router that can pick up signals from wireless Internet connections. Make sure that your wireless Internet router is close enough so that the Nintendo Wii can pick up a signal.
Loading Wii Shop;
Use your Wii remote to select the Wii Shop from the main Wii channel menu. The Wii Shop is located in the top right-hand corner of the screen. If your Internet access is not set up yet, then you will be prompted and automatically brought to the Internet Configuration menu. Once your Internet is set up, you will either be brought back to the Wii Shop or the main channel menu.
Navigating the Main Menu
Look at the main Wii Shop menu. Here you will be given two main options with a couple of general options at the bottom of the screen. The first option is to look for games for the virtual console. The Virutal Console contains games from past systems like Turbo Grafx 16, NEOGEO, NES, Super Nintendo and Nintendo 64. Once you have loaded the virtual console menu, you can search games by most popular title, new titles, system, genre or price. When you have found a game that you are interested in, press the "A" button to see a more detailed description with a couple of screen shots, and find out how many Wii Points the game costs.
Wii Points
Purchase Wii Points directly through the Wii Shop by using a credit or debit card. You will use the Wii remote to point and select all of the card holder information. The minimum amount of Wii Points you can buy is 1,000 for $10, so if you want a game for 700 Wii Points, then you will have 300 points left over for future purposes. Instead of using a credit card through the Wii store, you can purchase a Wii Points card at a local retailer. These cards come in different point values, and 100 points represents a dollar.
Downloading the Software
Finalize your game purchase by confirming how many Wii Points will be deducted from your account. Once you have done this, the game download will begin. While it only takes a few minutes to download, you can see the progress by watching a Mario character jump and hit a brick. Once he has reached the third brick, your download is complete. From there, you can continue to shop in the Wii Shop or play the game.
Wii Ware
Check out the other option that is labeled as "Wii Ware." Wii Ware is a lot like the Virtual Console, but everything created here is new and original for the Wii. You can get updated channels like the new Photo Channel or get exclusive Wii Shop games like "Midnight Pool" and "Family Table Tennis." The games here actually are interactive Wii games, and you can get the full game for a lot cheaper than a new Wii game from a store.
1helpful
I have Epson Projector and Acer Laptop both with DVI connections. How do I connect a Nintendo Wi-fit consul so I can play and hear the games. I have a wireless sensor.
I've never seen a projector with DVI ONLY -- double check your projector and all compartments and see if it has any other inputs. The wii can use the regular composite, red, yellow, white output. The wii can use SVideo and the Wii can use component output -- red, green, blue video and red/white audio. I do not think there is a DVI cable for the Wii.
Need my password or key for wii consule
You can find it out by looking at the router setup page:-
http://kbserver.netgear.com/products/WGR614.asp
Select your router model (v5,v4..) and look at the docs on the webpage.
You can login to your router by using one of these IP addresses http://192.168.0.1 or http://192.168.1.1 in your browser address bar.
You will see your network key under the wireless settings.
Hope this helps.
Wireless sensor bar needs setting up
http://www.nintendo.com/consumer/systems/wii/en_na/settingsSensorBar.jsp
The link above will show you how to set up a sensor bar
Bless you son for saying it's wireless lol :)
I hope this helps
Handsets not responding.The lights light up at first & then go out.Options appear on screen. Have tried new batteries & checked the black receiving bar is working (on a friends system). Has the syncro
Hi there heather.
it seems that your synchronisation could have been lost, bear in mind some Wireless connections such as that of the wii can be scrambled/lose single if there are alot of electrical appliances in close proximity, as this messes with the wireless signals being transmitted.
you may just need to Re-Sync your Wiimotes which is simple. on the underside of the mote, inside the battery compartment there is a small red Button, pressing this whilst pressing the sync button on your nintendo wii should successfully sync each mote to your wii allowing you to play :)
hope this helps
Nintendo wii consule (european german version)
The Wii Sports manual can be downloaded here
The manual for the Wii console itself can be obtained here
As for changing the language in Wii Sports, I am not sure, but it usually gives you the option when the game first starts up, otherwise it might use the system language.
Thanks.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
