Question about FMI Mini Wireless Optical Mouse with Slim USB Reciever (859611000516)
Difficulty getting my mouse to communicate
This is a great site. I have a mini RF wireless optical mouse 27Mhz 800dpi, that I cannot seem to get to communicate with or be recognized by my laptop. I'd really appreciate any help you can provide me. Thanks. Ron
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect buttonon the bottom of the mouse and press it. This should connect the mouse tothe receiver and work properly. If not, try pressing the receiver buttonand then press the button on the mouse. This should be done whenever youchange batteries or glitch. Hope this helps you. Bud
Posted on Jan 17, 2009
I have a ge 98563 ergonomic wireless mini mouse and my laptop wont recognize it
I have had no problems with my compaq laptop and the mini mouse. It recognized it even after OS downgrade to XP. The reset buttons on the mouse and the transceiver need to be activated or reset when sitting idle for a while. Once you get them both "blinking" it works great. Good mouse for the price... Your laptop should recognize it. Just check the reset and make sure the lites are on and communicating.
Nov 21, 2010 | GE Wireless Optical Mouse
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Mar 08, 2010 | BenQ M310 Wireless Mini Optical Mouse
What are the Pros & Cons between a ''Optical Wireless Mouse'' and a ''Laser Wireless Mouse''
The difference between a regular optical mouse and a laser mouse is the light used to track movement. A regular optical mouse uses an LED light in the optical engine, while a laser mouse uses a laser to track movement. The more dots per inch (dpi) a mouse can track, the more sensitive and accurate it is. A typical optical mouse tracks between 400dpi and 800dpi, while laser mice track more than 2,000dpi. Neither is really better; it all depends on your needs and preferences. Unless you're a gamer or a graphic artist with a need for precise movement, you'll probably find a 2,000dpi laser mouse too sensitive. Many gaming mice, however, allow you to switch sensitivity levels so that you have precision when you need it but can revert to 400dpi or 800dpi for regular mousing. Besides their tracking speeds, laser mice work on nearly every surface, whereas optical mice may experience trouble tracking on black or shiny surfaces.
Nov 27, 2009 | Computers & Internet
What are the parts of a mouse and their bases
For wireless mouse, it has a USB dongle or base that has transceiver to receive command from the mouse via RF signal.
The mouse has a laser underneath that detects the dpi (dots per inch) movement of the mouse. It also has transmitter that communicates with the USB transceiver via RF signal.
If you have more questions, just let us know by posting your questions.
Have a great day!
Sep 28, 2009 | Targus Wireless Optical Notebook Mouse...
How to replace batteries
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 14, 2009 | DPI nSpire AXM-105 Mini Rechargeable...
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
Targus RF PAUM005 Mouse Not Working
do you have the CD that came with the hardware???
seems like the PC can't communicate with the hardware. although it see something out there, but it doesn't recognize what it is.
even the machine is says this device is working porperly, you still need to install the driver, and the configuration for the device. that's why the receiver doesn't flash.
try to install the drivers and the configuration application.
Oct 23, 2008 | Targus Wireless Optical Mini Mouse
GE Wireless mouse & keyboard
are both keyboard and mouse communicating with a single wireless devices, or each has it's own? sometime you need to sync the signal to the wireless device. but do this first... ask your sister if the mouse was working before she gave it to you, there is a possibility that the mouse is broken/no working. if it's an optical mouse, the mouse that has lights sensor, make sure it lights up...
Feb 16, 2008 | GE Wireless Optical Mini Mouse 3087897985
GE wireless optical mini mouse
Not sure if it could be a mouse issue or a surface issue. Some things to keep in mind: 1. Most mice have a "channel" buttof on the bottom used to pair it with the wireless base. Try pressing this a few times to see if you get the desired effect. 2. Surface has a lot to do with quality of the mouse tracking beacon. I suggest dropping $10 on a mousepad. I have a mouse pad with a wrist rest I paid $15 bucks for and even though the mouse doesn't move as fast as on the desk, simple changes in the Control Panel for mouse tracking solved this issue. 3. I am not one to harp on a particular mouse manufacturer but I have had a great deal of good experiences with Logitechs line of mice and keyboards. Hope this helps. D.
Sep 19, 2007 | GE Optical Mini Mouse ho98094
Computers & Internet Logo
129 people viewed this question
Top FMI Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a FMI Computer and Internet Expert? Answer questions, earn points and help others
