Gpu what is the price of zotac 9800gtx amp ed comment on its performance regarding some games
  • 42 Answers
Hi.........
its about 10000 bucks and has a very nice performance in mid range section of gpu's
Posted on Nov 21, 2008
Dualgraphics
Hello here is the homepage:
http://www.asus.com/Motherboards/AMD_Socket_FM1/F1A75M_LE/#specifications
To enable crossfire, you must have 2 identical graphic cards.
The onboard graphic can`t be used with the hd6670.
This means that you must buy another hd6670 to add on the mainboard.
The graphic cards homepage:
http://www.asus.com/Graphics_Cards/AMD_Series/EAH6670DI1GD3/
AMD CrossFire technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance.
You also need a large power supply min. 500 watt to have enough power.
Please disable the onboard graphic in the device manager.
Good luck
Jan 06, 2013 | Computers & Internet
My 9800gt won't boot sends no signal to my screen and makes a clicking noice now this isnt right i know but whats causing it any ides guys
You might have a power supply issue, your computer might not be able to handle having it all powered so it's sending power to the GPU but not enough to send a video signal.
I'd suggest making sure you have a power supply on your computer capable of handling a graphics card this big.
Mar 03, 2011 | Nvidia Zotac GeForce 9800GT Amp Edition...
2 rings of death only when a play a video game. I had 3 red rings, then I did an x-clamp fix , cleaned GPU and CPU and applied arctic sliver to the xbox. When I start up my xbox it show no red...
Hello there
From what you have said it sounds like you have the RROD - 2 RED RINGS ERROR
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Jan 05, 2011 | Microsoft Xbox 360 Console
Gts 250 and psu problems
The dual 6 pin, I believe, is used so you can take power from the power supply and pass the connection back where it was taken from with a jumper. The card should need only one connection for power (But it IS needed)
Power supply is vital for a computer. From your description I would not get less than 600watt. The power supply should be rated at least 125% of what you need worst case.
Mar 21, 2010 | Express Zotac GeForce GTS 250 DDR3 2DVI...
Which gpu is good for bugdet and gaming
hi, to give quality display grafix for games you must have video card which is geforce 9 series and it has 1g with 256 bit.... and the minimum of 1g-128bit.. that will give you best for the games...
regards..
Mar 04, 2010 | Intel DG31PR Motherboard
Processors
well if compatible with your motherboard then you should get a core 2 duo- e6600 is a good performer if you can find it otherwise a e8400 is good. That graphics card sucks for gaming! The 1gb is irrelevant, you should try to get at least a 8800gt/9800gtx/ati 4850/4870 to game at high resolutions with high detail.
Apr 15, 2009 | Computers & Internet
"Call of Duty" runs in slow motion on my PC.
Hi thomas,
Upgrading video cards will definitely increase in performance. You asked whether you should upgrade your entire PC or just the card and that really depends on the hardware you are running. If all of your hardware just barely meets the requirements than upgrading the videocard WILL give you a noticeable improvement but obviously it will not be as good as getting a better CPU and more RAM as well as a new card.
A good measure of a cards performance is based on the series of cards it is from. Your Geforce is from the 6000 series of Nvidia cards, they have 7000, 8000, and even 9000 series cards atm.
I would recommend something like an XFX Geforce 9800 GTX+ series card with 512MB of onboard memory, or any other competing card in the 200$ price range. This will definitely give you an increase in performance, and is a very popular card.
Hope this helps and please take a second to rate!
Mar 20, 2009 | HP Pavilion a1610n PC Desktop
Running 9800GTX in SLI with 9800GTX+
Yes , All you need is the same GPU. The mem doesn't matter as they run to the lowest card.
Aug 26, 2008 | Computers & Internet
Xbox 360
Overheating GPU or damage GPU either way, you have to open your xbox and check if the GPU and the heatsink have thermal compound on it. Comment if it doesn't work.
Aug 18, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
