Sony projection tv HELP!!
HELP! One day my set will power on and cycle through video 3, video 5, dvd, cable box, and sometimes the actual program I want to watch will show up. Other days I can not even turn the set on. No flashing lights, and most of the time the remote will not work the TV. Any ideas??
    Brigadier General:
  • 6,966 Answers
Initially, let us try a simple one; flick/snap with your finger nails any and all of the buttons on the front control panel of the TV unit. The ides is to unstuck any of the buttons. They maybe in a pressed position. Incidentally, any sudden change in the weather/temperature? Any rain lately? Condensation, dampness, humidity maybe playing with the rubber pads of the controls or with the electronics inside.
Alternately, you can try the hard reset; unplug from the mains for an extended period of time, say an hour or more.
Should none be corrective, pls post back the exact model number.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 21, 2008
Convergence settings won't adjust color and fish eye effect
1) Check if it happens with different video sources like Cable, Cable Box, DVD Player etc.
2) If it happens, check for the Flash Focus settings in the TV or convergence.
3) If are able to locate and still convergence occurs, perform the power reset by disconnecting the power cord from the wall outlet and connect it back.
4) If the issue occurs, your TV may require service
Sep 22, 2009 | Sony Televison & Video
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
TV Help!!
Yes , this sounds like the EPROM IC is failing or the crystal that keeps the frequency on the IC needs to be replaced , or even the buttons on the tv could be warped by the heat of the tv( if it is the buttons , then removing the control board from the plastic buttons will stop the random cycle and may make it so you can turn on the tv , but if not then it is the EPROM IC or crystal)
to check and see if the chip is messing up , hold down the menu button on the tv or vol up down and see if it stops cycling thru the video inputs
electech
Nov 21, 2008 | Televison & Video
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No sound only get sound when dvd or vhs
Good Day;
No sound on what? DVD & VHS, okay?
Need more information:
1. Where don't you get any sound from?
2. Are you using cable box, sat.,or.....? What?
3. If box what type?
4. ANT, VIDEO, COMP, HDMI or ECT. inputs.
If you are using a cable box there are some boxes that have volume controls on them, please check volume level.
Please clarify what source you are using & check all 'other' cables.
Good Luck, Day, Big Irish.
Jun 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
