Question about Netopia 3-D Reach (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter
Netopia i an new to this computer stuff i just got high speed internet and i dont know what this netopia thing is for help.
  • Anonymous Feb 19, 2009
    I am not sure what this device is far.
Try here, they should use the same driver
Posted on Jan 14, 2009
How to change my router's MAC address Netopia 3397G
Using a router is a great way to create a home or office network without having to spend a lot of money.
As long as you have a broadband Internet connection through an Internet service provider, you can use a router to get all of the computers in your home or office connected.
If you have chosen Netopia as your router brand of choice, you will have to configure it to make your network operable.
Power on your Netopia router, broadband modem and computer.
Open your Internet browser.
Type the router IP address, 192.168.1.254, into the address bar. Hit "Enter" on your keyboard. Log into your Netopia router with the username and password assigned to you by your Internet service provider.
Select "Expert Mode."
After entering expert mode, you will see a menu bar at the top of the configuration window.
Click on the "Home" tab. Many Internet service providers will ship your Netopia router to you preconfigured.
If it is preconfigured all of the fields, such as IP address, subnet mask and default gateway will already be populated. If the fields are not populated, proceed to the next step.
Click on the "Configure" tab. Select "WAN." Select "ATM." Enter the "VPI" and "VCI" numbers provided by your Internet service provider.
Choose your encapsulation option.
For example, "Routed IP," "PPPOE," etc... Click "Submit."
Select "WAN" on the left side of your configuration window.
Choose the "VCC1" option. Select the option to "Enable Interface."
If you do not have your own IP address, choose the option to "Obtain an IP Address Automatically."
If you do have your own IP address, uncheck the automatic IP address box.
Type in your IP address if you have your own.
Enter your subnet mask.
This information can be obtained from your Internet service provider.
Select the "NAT" option if you are using your own private IP address for your network connection. Click on "Submit."
Ensure that there is a check in the "Gateway Option" box and "IP Address" is selected as the "Interface Type."
Type in your "Default Gateway" address.
This can be obtained from your Internet service provider.
Click "Submit."
Select the "Configure" tab at the top of your window. Select "LAN."
Select "Enable Interface."
Type in the IP address for your router and subnet mask. Click "Submit."
Click on the yellow caution symbol on the top right hand side of your window to save all configuration changes.
Click on "Save."
Restart your computer for the changes to become effective.
http://www.netopia.com/support/hardware/technotes/CQG_121.html
May 10, 2013 | Netopia Computers & Internet
Increasing internet speed
You can use the latest wireless modem,to get fast internet speed while uploading and Downloading ..You can also use the virus software and Firewall protection to maintain the speed,wireless is basically provides slow speed,you can make it fast using the tips,also install the latest browser,use torrent for uploading and downloading anything,you can also call the ISP to fix this problem,to check the speed of the internet at here Scanmyspeed.com
Jan 18, 2012 | Netopia 3-D Reach (TER/GUSB-N1)...
Will using netopia wireless usb card increase signal strength for internet on my laptop?
You can call the ISP to know whether that netopia card will helps to get more speed!!!
You can also use the latest browser and use wired connection to get fast internet speed,You can check the speed of the internet at Scanmyspeed.com
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
Internet speed has slowed. have 16 mg service but only getting 1.5 to 4 mg speed. cable guy checked everything out , says cable ok. 3 other computers in house ok. have run norton 360 twice. no virus...
I would delete all your temporary internet files first and if you are using internet explorer the do a reset and that should cure it. Also you could try chrome and firefox as they are faster than IE.
Jul 26, 2017 | Toshiba Satellite T135DS1325 NoteBook AMD...
I purchased an acer notebook and had high speed internet service installed. The problem is the acer will not connect to the internet, my pc will what can i do?
As you have high speed inernet connection setup a internet connection from your control panel in network and internet options and save new connection. YOUR old computer will be of great help as you can get all the required fields for configuring your setup of new internet connection in your new acer notebook
Aug 16, 2009 | Acer Aspire One PC Notebook
I have Netopia 3347-02 but i have a Wireless Error help!!!
As im sure you found out the hard way, you have to swap the netopia out. You must've really snapped your lucky fingers for that one. I do this stuff all the time for a living, and I've never seen a Netopia not function correctly, a new one that is from your ISP anyway. Did you get the netopia from your ISP? or did you buy it on E-Bay, or Amazon.com, a netopia from another ISP wont function properly, but the wireless still should.
Bad modem, just swap it out. Its under warranty, its a new modem, that model number just came out last year. You wont even get charge for it. Its just frustrating when new equipment fails, and unfortuanatly, its becoming more and more common place it seems. Don't even get me started on my new motherboards from ASUS.
If its not a project, its no fun, right?...hehe
spin
Feb 22, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia Router - No Connection, Clicking
Yes, you need to swap the router out.
This is assuming you dont have the netopia in bridge mode with another device behind it.
spin
Jun 26, 2008 | Netopia 3346N-ENT Router (3346NENT)
MacBook Internet connection
ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Feb 09, 2008 | Apple MacBook Pro Laptop Computer with...
Firewall help?
There is a great site for setting up routers for specific things. I found a guide for 3347NWG, I hope it is close to the enterprise one.
First you want to go here: Set a static IP on your XBox360
Then check out: Netopia 3347NWG (the static it asks for is the one you just made).
The menus should be similar on the router on that page to what you have. If it is way different I would not recommend doing it since a mistake here can kick everything off of the internet.
Hope this helps.
Jan 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 3-D Reach  (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter Logo
69 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
