Question about Arkon i.Trek M3 Bluetooth GPS Receiver (SiRF III) (V.3.1.1 WAAS) (Free Vent Mount and GpsGate Softwa... GPS Receiver
Unit will not pick up satelites
My unit all of a sudden stopped working. I use to get a signal from a minimum of 8-9 satelites. Can someone help with this? I use my GPS on my Treo 700w frequently. I have tried to rest the unit by removing and replacing the battery.
0 characters
1 Points
My GPS losses satelite if my MP3 is also connected
I'm thinkin that ur fm transmitter is interfeering with ur satilite signal. solution i suppose would be to purchase head unit that has sat and mp3 plug in capatible... or stop using ur fm transmitter while ur using ur gps.
Aug 01, 2012 | Navman iCN 320 GPS Receiver
No signal from satelite?
NO. satelittes work around the clock. Preoblem is either a- your unit is not picking up the satellites or b- you are trying to use it indoors. Personally i am going to go with a. Couple things you can try, Move the antennae to where it has a clear view of the sky, not foreward view but straight up and down view. If the unit has an external antennae try to put that as close to the windshield as possible and if it has a magnetic antennae then stick that out on the roof of the car. You should get a signal then.
If you don't get a signal i would suggest taking the unit back to where you got it.
Mar 12, 2010 | Virtual Reality VRVD640G GPS Receiver
My GPS that is only about 4 days old works fine sometimes but then it will say "Poor satelite reception" and then "none" what do you recommend?
Do you live in a an area with plenty of tall buildings/trees around you? Do you live in a valley? GPS units need to "see" plenty of clear sky to work reliably.
Does the problem occur the same whether you're using it in the car or on foot? Many modern cars have solar reflective glass which has a microscopic metal coating and it blocks satnav signals unless a supplementary external satnav antenna is fitted.
If you press and hold the nuvi's signal strength bar on the display for a few seconds you'll get a screen which shows how many satellites the unit is picking up along with a display which tells you how accurately the machine has fixed your position. It won't fix your problem but can help you find out what seems to be wrong.
If you're still having problems and these are not the causes then there's no point in doing anything further: just return it to the vendor for a refund or exchange as they are sometimes faulty straight out of the box.
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
Nextar m3 and no signal
You are facing this problem because of the US GPS Satellite because there's a sudden change with the code signal which leads to GPS signal anomalies.
Even though you've traded it. the problem is still there.
It's better to go with another brand or model.
As this problem cannot be fixed with this unit.
Jun 16, 2009 | Nextar Q4-04 Car GPS Receiver
My eTREX VISTA won't get a satelite fix any more
The unit needs to have the screen facing up. The unit will not read if it is vertical. Garmin cust serv finally helped me with that one. Once you turn on the unit, it could take up to 20 minutes (usually about 3) to grab satelites.
Mar 26, 2009 | Garmin eTrex Vista Cx GPS Receiver
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
Mar 07, 2009 | Tomtom ONE GPS Receiver
Magellan Maestro 3100
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Gps model 330
-after the units have been off for awhile...they need considerable time to reconfigure the satelites
  1. go outside with unit turned on
  2. find an open area...with a clear view of the sky...i.e. away from trees/bldgs/etc.
  3. wait...upwards of 20+ minutes...depending upon your unit
  4. it should be picking up signals continuously...and begin to calculate your location
-the above assumes that the unit has batteries, hasn't been dropped, etc.
-if that is the case....then the unit has other issues
Nov 06, 2008 | GPS Devices
Cannot get satelite signal for magellan triton 1500.
1) Walk outside and give the unit 3 - 5 minutes to acquire satellites.
2) Push the PAGE/GOTO button on the left side of the unit until you see the satellite page and see if you are picking up satellite.
3) If 2 and 3 do not work .. then reload the firmware again.
Aug 22, 2008 | GPS Devices
Myguide 4000
Yes correct! No more the Myguide company. Try another navigation system... not the factory default "PLUS".
I think it shoud works good with Igo 8.3 or 8.5 or Amigo
May 23, 2008 | MyGuide 3240 GO GPS Receiver
Arkon i.Trek M3 Bluetooth GPS Receiver (SiRF III) (V.3.1.1 WAAS) (Free Vent Mount and GpsGate Softwa... GPS Receiver Logo
15 people viewed this question
Top Arkon GPS Devices Experts
Are you an Arkon GPS Device Expert? Answer questions, earn points and help others
