Question about KitchenAid KERA205P Electric Kitchen Range
Message EO F2 on the panel
With the message comes a alarm that becomes more and more often as the time goes by
  • 367 Answers
EO and F2 means you have a shorted keypad. Or the oven temp is too high. The cheapest route to go is to replace the oven temp sensor first. If you give me the model number i can get the part number. If the oven temp sensor doesnt fix the problem You have to replace the electronic control. Check to see if there is a y near the end of your model number. if there is then it is most likely just the sensor. If there is no y then it is most likely the electronic control. (this is what my code chart says) But you can try the oven temp sensor anyway. It may fix it.
Posted on Nov 21, 2008
My ranger digital pannel have a message EO F2, what ir means..?? the brand is Kitchenaid
Is it E0 F2 or F2-E0? If it is a 4 digit panel and it shows F2-E0, then it is a shorted keypad and you have to replace it. Sorry.
Sep 06, 2011 | Microwave Ovens
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
CONTINUE TO GET THIS ERROR MESSAGE EO-F2
you may have an oven temp sensor out of wack. may have carbon on it . wires going to it may have burned
Feb 03, 2010 | Kitchen Ranges
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error message EO F2
that fault refers to a shorted key panel, recommended repair is to replace replace Electronic Range Control/Clock (erc)
Feb 24, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Control Panel Display Reading
mommaT, the code has to do with the keypad, key held down too long or stuck or shorted keypad. Have someone remove the key pad ribbon cable from the control board and clean the ends with an eraser. If that doesn't do it, you may need a new keypad. Catriver..post back
May 13, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
KitchenAid KERA205P Electric Kitchen Range Logo
103 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
