Question about Mitsubishi VS-5075 50" Rear Projection Television
Tv wiggs out with too much black
So basicly if its just turned on its fine as long as there isnt too much black in the video. If it gets to much black the top section of the tv will slide to the right very briefly and then reset. It also makes a buzzing noise inside the tv. It wasn't doing it when I was in the color alignment tool but after the tv was on for a while(15 mins) it started doing it alot more. This tv is only worth like 300 if that so I'm sure a shop would charge way to much. The tv has been used alot for the past 5 years and now we have a new plazma so is this junk?
    President:
  • 3,130 Answers
Sounds like the small PIP module is bad. there are several surface mounted caps that go bad on this set, located on the PIP module.
Posted on Jan 04, 2007
    Sergeant:
  • 308 Answers
This model is famous for capicators going bad, and would probably not be worth repair.
My Samsung SP-P4231 plasma television works fine for several hours and then the picture gets all wiggly and impossible to watch. If we shut the tv off and wait an hour or two and turn it on again, it works...
The tv main Tuner signal board have intermittent problems,sorry this problems it could be anythings wrong in the board as parts wise are dying in the tv Tuner signal board just not completely,that why it take times to show up,that the board where the tv incomming broadcasting signal cable plug into it.U can take things aparts and putting it back together again?Yes.Try website like Ebay.com to buy a refurbish main Tuner signal board for the replacement.Or take to the shop for the repair that it.
Apr 19, 2011 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
My three year old daughter pressed a number of buttons in some odd combination on my remote control which has made the screen have lines and and other sorts of glitches so that the images are not visible....
It mite be in progressive mode witch is for composite video if it is not hook up to the TV for progressive mode and is put in progressive mode the picture images are not visible and looks black and white and wiggly. Check owners manual on how to get out of progressive mode. Hope this helps kids will be kids.
May 22, 2010 | JVC XV-S60 DVD Player
I have a VA902B Viewsonic 19 inch lcd. When I plug it in, I get narmal video, but in a few seconds, I get wiggly lines, first around the edges, then all over. I can still see the images, but its wiggly. ...
power supply on your monitor is not stable. Could be 1 of the ballast transformer of the backlight in the monitor is overheating and soon to burn out, that cause the instability of the power supply.
May 17, 2010 | ViewSonic VA902b 19" Monitor
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Color problem green and pink
I had a very similar problem - the picture would get garbled, the black colour would turn into dark or bright blue tones, and i would get wiggly/jaggy outlines on the picture wherever contrasting coulours' edges met. After 2 service calls (replaced video boards both times), i gave up and popped the back cover on the TV. I wiggled a cable that connects the video board (it is on the top left quarter of the TV if you are looking straight at the front of it), and noticed that the picture improved right away.
I found that there is a bad solder on the cable connector, and simply keep the cover off now, as the connection will get flaky once in a while (especially in warmer temperatures).
Dec 05, 2007 | Televison & Video
TV picture was warped, no it is black, but the power light remains on...
the problem you are having is in the power supply you can go ahead and take your set to a repairman o look at your set good luck.
May 02, 2007 | Philips Magnavox MS3652S 36" TV
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
