Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Blows cloud of smoke
Heater runs fine , but while turning off (thermostatically), it throws a big cloud of greyish blue smoke . Using heating oil as fuel . How do we stop this from happening ?
    Problem Solver:
  • 5 Answers
Thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Posted on Jan 24, 2009
My isuzu kb 280 dtlx produces blue smoke and misfires it still has power thouh bt when u rev it the smoke turns greyish black and its conduption is very heavy
Blue smoke means burning oil most likely due to worn piston rings. Black smoke means car is running rich too much gas being burnt
Aug 04, 2016 | Isuzu Cars & Trucks
It sputters and belches out large clouds of blue smoke
mine recommends using only detergent oil rated API service classification SG-SL. Sounds like an older model and the synthetic may be to thin. Try changing the oil to a SAE 30 to see.
Apr 24, 2016 | Garden
Has grey blue smoke at ldle what is thecause.?
blue cloud --blue smoke means your burning oil can be from a number of reasons such as head problems --valve guides cracks in head gasket -scorched cylinder wall -piston rings aslo check oil if murky brown or greyish brown coolant getting in oil indicates more towards upper engine problems
Jul 27, 2015 | Cars & Trucks
Occasional heavy smoke on tickover, but not using oil and oil clean.
HI do you now the color of the smoke
if engine emits white smoke its not burning the fuel
it could be water mixing with fuel = head gasket even tho you
dot have water in the oil
if engine emits black smoke - that's excessive fuel to air ration
check air filter & air inlet to see if clogged
if engine emits blue smoke - excessive oil consumption
cloud be valve seals
Jun 28, 2011 | 1996 Volvo 850
Ignites about every one half second puff blue smoke when fire puff blue smoke will not run continous
statelinespe,
You have a classic reddy heat problem. Daytons are made by Desa the same as reddy heat so they are the same. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix it.
Thanks fo using FixYa and for the great rating.
hardrocko
Dec 29, 2010 | Dayton (3VE50) Oil Filled Liquid Fuel...
2003 vw passat turbo leaking oil cost to repair
might just be a feed or return pipe unless its throwing big clouds of blue smoke out of exhaust ,please be more specific
Aug 03, 2010 | 2003 Volkswagen Passat
CHUCKS OUT CLOUDS OF BLUE SMOKE.
Blue Smoke: Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with the white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles.
How did the engine oil get inside the cylinder in the first place? The car has many seals, gaskets, and O-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plug, it will cause a misfire (engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Jun 07, 2010 | Fiat X1/9 Cars & Trucks
Heater smokes but doesn't turn on
It sounds like you have a dirty nozzle. Remove and replace with the same type. It may not be spraying a fine enough mist.
Hope this helps.
Matt
Jan 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
228 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
