Question about Panasonic DP-150FX Laser Printer
1 inch black stripe down edge of page
My Panasonic DP 150 has a 1 inch black stripe down the side of the page when I FAX something. (The recipient of the fax see this)
When I copy something about 1/3 of the page is solid black (at an angle)
    Sergeant:
  • 284 Answers
Can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Posted on Nov 21, 2008
When sending a fax the pages do not go through the feeder until the connection with the recipient is made. Once made it pulls the papers one by one. It will not store and send. This was working fine up...
fax memory switched on documents held until other machine answers then transmits page by page fuction parameters of fax side of machine fuction 7 then 4 switch memory to on . the only other way the machine will send like this is by a manual dial when the hook button is pressed then the number put in the documents are held until the user is prompeted to press the start key
Oct 28, 2011 | Panasonic DP-8020E Black and White Copier
Workio 150 fax - won't go direct to fax always
You change to the defult setting of your copier sold be set on fax. Try this link and download the operating manual. hopefully this will help you.
http://panasonic.net/pcc/support/mfp/
Jul 07, 2011 | Panasonic Workio DP-150PA Copier
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do you setup the email address book on the Workio dp-150?
You might be able to download a manual here:
http://www.retrevo.com/s/Panasonic-DP-150-Copiers-review-manual/
I'm not sure that model supports emailing scans. I couldn't find it in the manual. Just setting up the fax phone book on page 139.
May 01, 2009 | Panasonic Workio DP-150PA Copier
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Black stripe down one side of every fax
On my Brother fax machine, there is a blue plastic cleaning thingy on the toner cartridge used to clean the metalic wire. If you leave it on the wrong side after cleaning, you get a thin black strip down the edge of every page. Slide it over to the other side and problem goes away.
Jul 08, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Panasonic DP-150FX Laser Printer Logo
152 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
