Question about BenQ FP91G+ 19" LCD Monitor
BenQ FP91G+ Problem
When I press the power button on a BenQ FP91G+, the power light comes on for about 1 second and turns itself back off. I have been trying to find out what part is causing the problem as I have several to repair. Any assistance you can given will be greatly appreciated.
    Champion:
  • 293 Answers
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Posted on Nov 21, 2008
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
MY COMPAQ CQ56-129NR when turn on the power light comes on then cap light blinks but no start up screen. Screen stays black what can i do if anything?
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 21, 2011 | Computers & Internet
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
We had a power out for a few seconds and the bl 2170w only comes on for less that a second. If I hold the Go button when it is turned on the 3 indicator lights stay on. If I let go and repress the Go...
Unplug the power to the printer before the power comes back on to avoid any damage due to surges when the power is back. After the router is back on and working. Plug your printer back. Then press the blue button for 10 seconds so that the setup page is printed. Your printer is now back on.
Sep 30, 2010 | Brother HL-2170W Laser Printer
Benq FP91G 19'' fades out
Capacitor problem on the power board internal solder fix is possible.
Jan 31, 2010 | BenQ Computers & Internet
Benq monitor powers off immediately
Try sending monitor back as most Benq monitors come with at least a two years silver warranty. Benq are very helpful and their repairers are quick and polite. You will find their no.s on their website www.benq.com my monitor was experiencing the same and for $10 postage and a one week wait is repaired and working fine.
Apr 07, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP91G+ 19" LCD Monitor Logo
613 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
