Question about HP Photosmart C6180 All-In-One InkJet Printer
The printer only stays on for one minute then shuts off
I have a HP C6180 Photosmart all-in-one printer. In order to get the printer even turned on, I have to apply pressure to the cord that inserts into the AC adapter.
  • 1 more comment
  • prohrkaste Nov 21, 2008
    No. Do you know where I can purchase a replacement for this part AC power Adapter 0957-2105?
  • prohrkaste Nov 24, 2008
    This was just what I needed
  • P. Thomas
    P. Thomas May 11, 2010
    that means that either the power cord is weakened, and not making connection, or the ac adapter needs to be replaced..do you have the means of checking continuity on the power cord?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Check the following weblink and if issue persists replace the power module and power cord.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00865701&dlc=en
Regards,
Sagarjd
Posted on Nov 21, 2008
Can i print magnets on my hp photosmart C6180?
Your printer HP Photosmart C6180 cannot read Films or magnetic tapes etc.
Regards,
Suhail
May 17, 2012 | HP Photosmart C6180 All-In-One InkJet...
Have HP Photosmart C6180 all in one printer that continually turns on and off, the orange exclamation sign lights up & the screen says "To avoid damage, use the On button to shut down the printer. Do...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the printer was having. 3ace550.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these
Jul 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One err oxc18a0201
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
good luck
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
My Hp c6180 printer has error masage " Improper shut down"
I had the same problem. Try shutting it down by holding the off button and unplugging it for a few seconds from the back of the printer. Wait a couple of minutes and them plug it back in. Make sure you are connect to a wall outlet and not a power strip or surge protector.
If this doesn't work, hold down the #6 key while cord back from the printer.
Hopefully one of these two would work.
If it doesn't you can go to the HP site and start a chat with a tech who will walk you through a solution.
I had the same problem, and got resolved.
Aug 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart C6180 all-in one
Your manual can be viewd / downloaded / printed here, directly from HP:
http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
The fax setup section starts on page 33.
Apr 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
