Question about Corona 23-DK Compact Heater
Fumes i bought this dk22 used and it puts off very bad odor my garage stunk for a week?
  • odnrck1 Nov 21, 2008
    my heater is putting off bad fumes?
  • 3 Answers
Generally a kerosene heater will put out a strong smell for a few minutes after it is first lit, and for a few minutes after you put it out. Generally, it will be much stronger after it's extinguished. I usually extinguish mine and immediately set it out on the concrete porch to keep the smell out of the house.
Opening a window for a few minutes right after lighting the heater will help with the fumes at startup.
If your heater is constantly putting off fumes, even after burning for a little while, then it may be time to burn the wick dry. This should be done every few months anyway as general maintenance.
First, siphon all the fuel from the tank. You will need to disassemble the heater and gain access to the top of the wick. Raise the wick to it's highest point and use your fingers or a flat nosed pair of pliers to break up the hard black tar coating on the top of the wick. The smaller you can break the coating, the faster it will burn off. Once thats done, reassemble your heater, raise the wick to it's highest point and light it. It will probably burn for an hour or two because it will first burn all of the fuel soaked up in your wick, but then it will burn off the tar. Finally, it will go out.
After this, you should be ok, to refill your heater and relight as normal.
If you find when you disassemble it that the wick has a hard tar ring down inside, you may have a hard time breaking that up and cleaning it. It is possible... But I would probably just replace the wick.
Posted on Dec 05, 2008
Why my 2005 scion xb has a smelly exaust fumes, no exaust fumes color. it pass the smog.
This sounds too me like the catylitic converter is getting bad, tapon it and see if it rattles. This is usually what causes a sulfer like odor coming from the exhasr.
May 25, 2014 | GE Pipe exaust & rivet - WE14M101
Leaky rear main seal
I bought a 2000 RL used, with some factory warranty remaining, and then bought an extended warranty. While hnder warranty, car began to smell up my garage from fumes from oil dripping onto hot exhaust. Not enough oil at that point to show up on garage floor. Complained to dealer about the odor but Acura Master Mechanic (said he) couldn't find source of odor (although I told him I suspected an oil leak because I had prior experience with oil leaks and resultant smells on another car). On the next service visit after the extended warranty expired, same master mechanic said my RL's rear main oil seal was leaking onto exhaust causing odor. And the dealer wanted north of $1000 to fix it. I declined. Leak has steadily gotten worse - now visible drops on garage floor. An independent repair shop quoted $650 plus the cost of replacing expensive, special Honda transmission fluid. Took my complaint all the way up the chain to the head of Honda in Japan, but got no assistance. No more Honda products for me.
Apr 05, 2014 | 2000 Acura 3.5RL
We have a rinnai convector gas heater and when we turn it on it fills the room with a horrible gassy smell.
There are a couple of things that can cause this odor. But, being sure it's really a gassy odor is more important. It must smell like "rotten eggs" to be gas. If that is the odor you're smell, turn the heater of and contact an authorized Rinnai dealer for service.
If however the odor does not meet the "rotten egg smell", there are other things that cause the odor, but it's not really from the heater.
If you have painted or stained within the last 2 weeks, the heater has picked up the odor of the fumes (which you probably didn't notice) and has made time 50 times worse. The same holds true for carpet cleaning or new carpeting odors. If this fits the scenario, discontinue using the heater for a week or two until the odors subside. In the meantime, if weather allows, air the house out. Also, remove and clean the heaters filter, before restarting the heater,
I hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
I have a 30,000 btu ventless mr heater for two months it has run with absolutely no smell,the other day I did some wood staining, now the heater has a strong co2 smell is their any way to clean the heater...
Sure is. Never operate a vent-free gas appliance (not even the pilot light) while painting, staining, cleaning carpets, etc. It picks up the odors and will not burn the odor off, because the odor doesn't get in the heater, it just makes the odor worse. You will need to turn the heater off and not use it, until ALL of the odor from the staining have completely dissipated . It may take a week or more, even though you may not be able to smell the odor from the stain, the warm moist air from the heater will activate it again. If you get a warm day soon, open a window or two and let the fresh air in. That will help dissipate the odor. But, allow a week minimum, before trying to use the heater again.
Oh, by he way, that wasn't co2 you were smelling. co2 is dry ice. It has no odor. Just like co (Carbon Monoxide) it has no odor. You were smelling the fumes from the stain. Just 50 times worse.
Good luck to ya,
Rich
Mar 02, 2011 | AOC Heating & Cooling
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
I recently brought a Crosley fridge and put it in my garage. A few days ago we opened up the freezer section and everything thawed out and spoiled and stunk. The fridge part smelled as well. We lost over...
This makes no sense. The sensors are supposed to sense the internal temperature of the fridge/freezer, not the room temperature! It is faulty, get it repaired under the manufacturers warranty and if the manufactures agent says it is faulty, they are liable for your loss.
Mar 26, 2017 | Refrigerators
Heavy smell
This is a fuel delivery problem. Look for:
  1. always start troubleshooting fuel problems on a Hot Surface Ignitor heater by checking the pump pressure!
  2. restricted fuel filter
  3. air leak
  4. restricted nozzle
Troubleshooting tips
Nov 17, 2008 | Reddy R60A Utility Heater
Corona 23-DK Compact Heater Logo
179 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
