Question about HP Office Equipment & Supplies
1.Very ,very slow letter prints 2 Distorted colours (mainly red0 on photoes
  • ronofidle Nov 21, 2008
    Have already adjusted settings and followed all checks on printer help. Printer Photosmart 7762 has been fine for 2/3 years and suddenly gone wrong. Photos are unuseable and a short note takes 3 minutes to print ( prev. 3 seconds)
    Genius:
  • 2,035 Answers
  1. Turn on the printer.
  2. Press the MENU button.
  3. Use the up and down arrows to highlight Tools.
  4. Press the OK button.
  5. Use the up and down arrows to highlight Print test page.
  6. Press the OK button.
  7. And check if all the colors are fine ,
Try to unplug the cable all the cables for 5 min and then power it and try to print and please let me know if your facing the same problem ..
Posted on Nov 21, 2008
  • 10,515 Answers
Cause There are seven common causes of slow printing from Microsoft Windows:
  • An incorrect printer driver is selected.
  • The HP Colorsmart driver is set to Best and Glossy or Transparency paper.
  • The system resources are being used by other applications.
  • The computer system is running at the minimum requirements.
  • Bidirectional communication is interfering with the printer operation.
  • Excessive temporary files are using up the system resources.
  • A large number of fonts are installed.
Solution one: Hard reset the printer
  1. Turn the power off. Remove the power cable and the data cable from the unit.
  2. Connect the power cable directly to a wall outlet.
  3. Reconnect the power cable to the unit and turn the power on.
  4. Print a self-test.
  5. If slow printing is still an issue, proceed to the next solution.
Solution two: Ensure the correct printer driver is installed and set as default Verify that the correct printer driver is installed and set as the default printer. If slow printing is still an issue, proceed to the next solution. Solution three: Verify the driver settings for Print Quality and Paper Type are correct Windows 95, 98, and Me
  1. Select Start , Settings , and Printers .
  2. Right-click the HP Deskjet icon and select Properties .
  3. Verify Paper Type is set to Plain Paper .
  4. Select the Setup tab and verify Print Quality is set to Normal or EconoFast .
  5. If any changes were made, try printing again. If slow printing is still an issue, continue to the next solution. NOTE: The size and complexity of the documents that you print can make a difference in your printer's performance. Graphics are usually more complex and print more slowly than a file that contains only text. Setting the Print Quality to Econofast can improve print speed; however, EconoFast produces the lowest image quality.
Windows XP
  1. Click Start , click Control Panel , and then click Printers and Other Hardware .
  2. Click View installed printers or fax products .
  3. Click Printing Preferences .
  4. Click the Paper Quality tab
  5. In the Quality Settings, select Normal or Draft .
  6. Try printing again.
Solution four: Turn off all programs Verify that no software programs are running. Windows 95, 98, and Me
  1. Close all running applications and try printing again. Use the steps below to close the running applications.
    1. On the keyboard, press Ctrl + Alt + Delete to retrieve the Close Program window.
    2. Highlight any program in the list (except Explorer and Systray) and click End Task .
    3. Repeat Steps a and b until all programs (except Explorer and Systray) are closed.
    4. Once the list shows only Explorer and Systray, click Cancel to close the Close Program window.
  2. Try to print again. If the print speed has not improved, perform Steps 3 through 5.
  3. Disable any applications that are loaded with Windows from the LOAD= and RUN= lines in the WIN.INI file.
    1. Select Start and Run .
    2. Type SYSEDIT in the Open box and click OK . Select the title bar that reads C:\WINDOWS\WIN.INI to bring that window to the front.
    3. In the [windows] section, locate the load= and the run= lines. If there are any statements in these lines, place a semicolon (;) at the beginning of each line. The lines should now read ;load= and ;run=.
    4. Select File and Exit . Click Yes to save the changes.
  4. Move all icons out of the StartUp program group.
    1. Right-click Start and select Open . Open Programs and StartUp .
    2. Move (drag and drop) each icon located in the StartUp window to the Desktop. Once all the StartUp icons are on the Desktop, close the open windows.
  5. Restart Windows and try printing again. If slow printing is still an issue, continue to the next solution.
Windows XP
  1. While holding down the CTRL and ALT keys on the keyboard, press the DELETE key. The Windows Task Manager appears showing a list of all running programs.
  2. Select a software application from the list and click End Task to forcibly close the software.
  3. Continue closing software applications until done.
  4. Click the Processes tab.
  5. Select the process (task) you want to close and click End Process .
  6. If another window appears stating the task has stopped responding, click End Task .
  7. Continue ending processes (tasks) except for Explorer.
  8. Try printing again. If slow printing is still an issue, continue to the next solution.
Solution five: Verify that your computer meets the minimum system requirements System resources that have a significant effect on print speed are the following:
  • The processor used by the computer
  • The amount of available random-access memory (RAM)
  • The amount of free disk space
Using a computer system with a faster processor, more RAM, and more than the recommended amount of free disk space will provide better performance than a system that only meets the minimum system requirements. The minimum system requirements for your printer are listed on the box your printer came in. The minimum system requirements to use your printer can also be found on your printer's web page. If your computer meets the minimum system requirements, continue to the next solution
  • taran_2005
    taran_2005 Nov 21, 2008
    Solution six: Validate that bidirectional communication is not interfering with the printer operation
    Try the following steps:
    2. Right-click the HP Deskjet printer icon and select Properties , Details , and Port Settings .
    3. Remove the checkmarks next to Spool MS-DOS® Print Jobs and Check Port State Before Printing and click OK .
      NOTE:
      If DOS applications are being used with an HP Deskjet 720c, 820c, or 1000c series printer, the option Spool MS-DOS Print Jobs must remain checked in order to allow the DOS applications to print.
    4. Select Spool Settings and select the option Print directly to the printer . This will change the Spool Data format from EMF to RAW.
    5. Click OK , Apply , and OK .
    6. Select Start and Run .
    7. Type the name of the HP configuration program in the Open box and click OK .
    8. Click Continue .
    9. Remove the checkmarks from any of the following entries that are present and click OK .
      • Network Bidirectional Communication
      • Launch Toolbox when Printing
      • Run Status Monitor when Printing
    10. If prompted, click Restart Windows .
    11. Try printing again.
    Solution seven: Remove temporary files to free up resources
    Delete unneeded temporary files.
    NOTE:
    Delete temporary files carefully to ensure that necessary files are not deleted. All temporary files use the extension .TMP. If you are unsure about the proper procedures for identifying, locating, or selecting temporary files for deletion, contact Microsoft Windows Technical Support for assistance.
    Windows 95, 98, and NT 4.0
    1. Right-click Start and click Find .
    2. Search for all *.TMP files on the C:\ drive.
      1. Type *.TMP on the "Named" line.
      2. Type C:\ on the "Look in" line.
      3. Make sure there is a checkmark next to Include Subfolders and select Find Now .
    3. If any files are returned in the Search Results list, delete them.
      1. Select Edit and Select All .
      2. Select File and Delete . Click Yes or Yes to All .
    Windows XP
    2. In the "All or part of the file name:" box, type c:\*.tmp .
    3. Click Search . A list of files with the .TMP extension will be display.
    4. Delete the unnecessary .TMP files by highlighting them and pressing the Delete key.
    Windows Me and 2000
    1. Right-click Start and click Search .
      1. Type *.TMP in the "Named" field.
      2. Type C:\ in the "Look in" field.
      3. Click Search Options .
      4. Ensure there is a check in Advanced Options .
      5. Ensure there is a check in Search Subfolders .
      1. Select File and Delete .
      2. Click Yes or Yes to All.
    Solution eight: Reduce the number of installed fonts
    Windows keeps track of all installed fonts in the memory. Having a large number of fonts installed will reduce the amount of memory available for Windows applications to use. Removing unused fonts can release some of this memory for use by Windows applications, which may improve overall system performance.
    Windows XP
    1. Click Start , then click Control Panel .
    2. In the upper-left corner, click Switch to classic view .
    3. Double-click the Fonts icon.
    4. You may delete any font that will not be used.
      1. Highlight the font(s) that will not be used. Multiple fonts may be selected by holding down the Ctrl key while selecting each font that is to be deleted.
      2. Select File and Delete . Click Yes to remove the selected font(s).
      3. Repeat Steps a and b until all unneeded fonts have been removed.Try printing again.
  • HP Master
  • 19,396 Answers
Throw the printer away and buy a new one.
  • Ginko
    Ginko Nov 21, 2008
    The only setting that can do this is printer resolution, lower down printer resolution on printer settings.
    If this does not fix it it is probably a faulty encoder strip.
    Note some of the complex and long procedure posted do not apply to your case, and will result only in a waste of time, just lower resolution to 150 DPI for standard paper and 600 DPI for photos, and see if it prints.
    Sergeant:
  • 276 Answers
The problem which you r getting is a common problem in this printer.as to resolve this problem three things must be done. 1)printer must be serviced to make the gears to run fluently. 2)replace the inkjet cartridges. 3)uninstall the printer drivers and then reinstall the drivers again.reinstalling the drivers will automatically create a new settings for regular printing. this will help you. thanks.
  • 586 Answers
    Uninstall it from your pc and then reinstall.
  Thanks
  • HP Master
  • 1,879 Answers
Perform a Windows Test Page from the printer properties page please and post back the result.
(Printers & Faxes -> right-click the printer icon and click the print test page button at the bottom)
    Genius:
  • 1,550 Answers
Just change the settings .
  • SAM ANDERSON Nov 21, 2008
    Better reinstall the driver file for your printer with proper updates from the hp website and take a test print after installing the driver file .
    If you still have the problem check the cartridge alignment in your printer .
How to fix double vision print?
Hello
The duplicate print is a problem you can fix easy, only need...
1. calcium grease
2. and put in the iron making
with the next steps...
Solving problem of duplicate letters in Canon printers
http://www.en.rellenadodecartuchos.com/2015/11/solving-problem-of-duplicate-letters-in-canon-printers.html
Nov 19, 2015 | Canon PIXMA MG3550 Inkjet Multifunction...
Epson Stylus Photo PX800FW doesn't print text
printer working ok-did 50 colour photos ,6x4 when i made a mistake and pushed the print button when there was still about 1 inch of the previous photo still being printed.This print emerged with overprint of about 1".Thereafter the printer has refused to operate properly the next print being heavily discoloured.It then told me to replace the light magenta cartridge-this I did and the discolouration changed hew.It then told me to change the magenta and light cyan carts.-I did and discolouration changed again.It then told me to change the yellow and cyan=siscolouration now bright
red over coloured. I then successfully printed a letter in B&W proving that the black cartridge was still working.However as soon as I tried again to print a coloured photo it now tells me that the machine does not recognise the black cartridge and orders me to change it and until I do refuses to take any instructions telling me to install the black cartridge cprrectly.The black cartridge installed isout half full and has successfully printed copies and photos.I have carried out the suggested remedies by the machine and none were effectuve.How do it the infernal machine working again???
Oct 11, 2009 | Epson Office Equipment & Supplies
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
I changed the black and colour print cartridges in my MP210 and the colour printing is all the wrong colours
Reinstall your printer driver software and do a test print before. If the test print prints fine then you probably have an issue on your main motherboard.
Jan 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
The HP laserJet Colour printer
I have reduced the size of the mega pixals on the digital camera before taking photo graphs this appears to have fixed most of the problem.
Apr 05, 2008 | Office Equipment & Supplies
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Printing Photo's is too light.
First thing, are your printer ink cartridges empty?  If it is, or is very close to it, this may affect the quality of your photos.
If quantity of ink is not your problem, did you go under printer properties, and in options/settings---check the slow speed, or maximum quality of your photo.  You can even check what type of paper you are using so the printer can sdjust more specifically.
Feb 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
Printer won't print excel sheets
checka all the lettres are in excel are in black colour only or check the printing mode. bye
Sep 24, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
22 people viewed this question
Ben Johnson
