Thin black line on Xerox 4011 laser printer
I get a thin black line about 70mm from lead edge. Only on 1st copy out if multi copies of same page selected for printing, but on every copy if single copy of multi-page document selected.
  • PellattUK Nov 22, 2008
    The problem occurrs with any type of document and test page sent from any processing software, even test print from printer driver gives same fault.
    Scholar:
  • 78 Answers
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Posted on Nov 21, 2008
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
Xerox docucolor 1632 has lines through out the page when i make a copy
most likely your imaging unit. Easy to find out
put a new one in and if problem is solved that is it
if problem persists there are 2 optional problems:
1)laser light obstruction - take imaging unit out look into the cavity, use a flashlight, try to see if there is any fine lint hanging around the opening where laser light comes from
2) your fusing rollers might have a scratch on them. For that you will have to call for sevice
Hope that helps
Feb 06, 2012 | Office Equipment & Supplies
Unwanted "line" on copied documents
Open the document feeder and clean the scanner glass.
Jan 21, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Xerox Copier Model XC1020
if the paper is black and the copies are coming out there is a problem with
1) the drum,
2) the transfer unit--- the unit under the drum, with thin wires,
Jan 08, 2009 | Xerox CopyCentre C20 Black and White...
Phaser Printer 8550 leaves black lines
There is a wiper blade between the print head and the drum. Sounds like you have some buidup on it causing your problem.
Nov 13, 2008 | Xerox Phaser 8550DX Laser Printer
Line down page on copies
what kind of line. Is it solid and think with well defined edges or is it a small thin and dotted? If it is solid with strait crisp edges you will need a new scanner. If it is just a small somewhat dotted you might just have a little something on the scanner glass. Clean it with regular rubbing alcohol and a cotton cloth like an old t-shirt. Don't use swabs or tissue because they can leave lint behind and just give you more lines.
Feb 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
Cranking noise when is turn on
We had this same problem.
A tech had to come in and replace a cog in the back.
Nov 20, 2007 | Office Equipment & Supplies
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
