Question about Car Audio & Video
Memory My UV8 will shut off power and never memorizes that station settings?
  • 20 Answers
The unit should have a battery wire yellow in colour and can be wired straight to the positve terminal of your battery,,hope that helps,,goodluck.
Posted on Dec 01, 2008
Car stereo always goes to same unprogrammed station when powered up
That tells me thatyour memory fuse is blown. You meed constant NOT SWITCHED 12 VOLTS TO MAINTAIN MEM
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Feb 17, 2013 | JVC Kd-r530 In-dash Cd Receiver...
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
Mar 03, 2011 | Alpine CDE-7853
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
How do i set radio stations on my car stereo j.v.c. kd s6060
Select radio from the source and select FM as the band. Now use an auto search or a manual search and as the signal locks you can hold on the preset button ( start from1) to be memorized on the set. you can repeat this for all the other stations. Punch in the frequency if you know it and memorize.
Feb 08, 2011 | JVC Car Audio & Video
Y sony direct comparator st s444 es 2 does not hold radio stations. Once power has been turned off for more than a couple hours, memorized radio stations are lost. Thank you
You could try looking for a memory retention capacitor on the circuit board. It will be on the board with coils etc. They sometimes are marked on the board. However they look like squashed electrolytic caps. They have a value of between 0.022 and 0.047UF and a voltage of around 5.5 volts. If you see one like that and it's near an IC then you found the trouble, replacement should stop the loss.
May 15, 2009 | Audio Players & Recorders
Hitachi ft 5500 tuner, tuner pre set problem
I bought an FT-5500 in 1983 that I haven't used for ten years but I still have the manual which states the following re pre-sets:
1. Tune into the station to be memorised with the tuning key.
2. When the memory write key is depressed the memory write key indicator lights continuously for about 5 seconds after the FCCS operation with FM reception and immediately with AM reception. One of the 10 preset keys is depressed for memorising the station while the indicator is lit. When the key is depressed the indicator goes off, the memorizing operation is completed and the next time you want ot listen to the station it can be recalled by depressing the corresponding preset key.
If the preset key is depressed during this interval and the FCCS data & broadcassting station are memorised the indicator goes off.
There is more but I think this should be enough to get you going.
Cheers
Graham
Apr 25, 2009 | Electronics - Others
Stereo will not save time or set stations. not
sounds like a very common power wire issue. if not connected to the cigarette lighter or other continous power source when the car shuts off all memory will be lost, ie... audio settings, station memory, clock memory
Feb 18, 2009 | Sony CDX-GT110 CD Player
Wand won't release
Quoting from page 6 of the manual:
"Select the radio band and tune in a desired radio station you wish to store in the preset memory.
Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) that you want to store the station on. The selected station is stored. The display shows the band, preset number and station frequency memorized. A total of 18 stations can be stored in the preset memory (6 stations for each band; FM1, FM2 and AM). If you store a station in a preset memory which already has a station, the current station will be cleared and replaced with the new station."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=934dc6a1672f80b9d320c470df81f04d&q=Alpine+CDE-9842
Feb 25, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Program stations
Feb 25, 2008 | Alpine CDE-9842 CD Player
Onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Nov 20, 2007 | Onkyo TX-8511 Receiver
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
