I paid 9.95 for assistance and did not get a responce but charged
My CRT sim2 multimedia projector has a very bright green projection with horizontal lines and no TV output. It will display for a couple minutes and then shut off.
  • 55 Answers
From your description it sounds like G2 voltage on the green picture tube is too high.
Are you confident about adjusting it yourself? There are high voltages in places which can kill. I will not take any responsibility of you getting an electric shock so I suggest calling in a qualified TV technician.
Any TV technician should be able adjust this voltage and it should not take long to do it unless the cases are hard to remove and hard to access the flyback transformer where the G2 (screen) adjustment is located.
Otherwise it may be a faulty green picture tube and this is expensive as you need to get the tube replaced.
Hope this helps
Posted on Dec 01, 2008
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
Power LED stays red - does not want to turn on
hi maybe I am very late for this, but do you still have the SIM2 D10?
I need some part if of course you have it and it still broken.
Thank you for your reply
Jan 20, 2010 | SIM2 Domino D10 Home Theater Projector...
Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Jul 15, 2009 | Office Equipment & Supplies
I have a sim2 ht300 and the picture is upside down. can you help.
Just go in the projector menu and there is a setting from where you can rotate the picture. Joe
Jan 10, 2009 | SIM2 HT300 Multimedia Projector
Trying to update Firmware on a Sim2 HT300
Take it to an Authorised SIM2 service agent . Some things are just not for the DIY
Dec 19, 2008 | SIM2 HT300 Multimedia Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Replacing the lamp in SIM2 ht-200
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
May 28, 2008 | SIM2 HT300 Multimedia Projector
Sim2 domino 20
Hi there
I checked the manual of your Sim2 , but they don't even mention the lamp in there.
You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
Jan 17, 2007 | Sony VPL CS1 Multimedia Projector
I have the 51" rear projection (kp-51ws520) and problems...
The same problem?? Sounds like a green crt driver is defective or the green crt is bad.
Aug 14, 2006 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
