Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
Kitchen Aid diswasher controls don't work
I have the Kudi02frss diswasher it is about 5 years old. The button for "Baked on Cookware" has stopped working. The other cycles work fine. The button itself is in excellent condition. Do you have any suggestions? Thanks.
I had a similar problem with a KUDS01... model. The Baked on cookware and the high temp switches did not operate. The normal light would come on but the machine would not run. I opened the front to expose the timer/controls. There was quite a bit of debris around the circuit board and micro chips. I vacuumed out as much as I could and loosened some with a tooth brush and blew it out with compressed air.
When I powered it back up all buttons worked and the machine worked.
Posted on Sep 06, 2012
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Posted on Oct 03, 2007
My dishwasher will work only on "baked on cookware" cycle. What is wrong??
Your timer or control unit whatever you want to call it has probably failed.
Dec 13, 2014 | KitchenAid Dishwashers
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a Kitchen aid dishwasher model # kudpo1ilbs6 the clean light is blinking 7 times then stops for a sec and does it again
I am assuming the problem does not go away when you turn the mains power off and on.
The problem is linked to the temperature variation in the incoming water.
This confuses the diswasher. You have to reset it now. Try this sequence..
Press heated dry, normal heated dry, normal quickly within 5 sec. All lights should light up.
Advance through the cycles by using the start button
Please post a comment to confirm if this helps.
Oct 12, 2010 | KitchenAid Dishwashers
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
What cookware to use on this cooktop
flat bottom cookware no rings on the bottom and no glass cookware
Apr 30, 2008 | GE JSP69 Electric Kitchen Range
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
395 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
