Question about HP LaserJet 3150 All-In-One Printer
Receiver Errors on LaserJet 3150 all in one fax
We keep receiveing errors on our incoming faxes. The fax machine says "Receiver Error"
Then it spits out a fax with just a black lin at the top and sometimes it has a small part of the image at the top and onthing else. I do believe that the sender of the fax gets a confermation that it was sent correctly. Not 100% sure on that.
THanks
Audra Bunch
  • 1 more comment
  • abunchpromed Nov 21, 2008
    Yes it is sending faxes fine. I am receiving some faxes fine also
    An auto activity report just printed. It is giving us a communication error code 791 mode EC144
  • P. Thomas
    P. Thomas May 11, 2010
    ok..can it send faxes ok?
    Problem Solver:
  • 15 Answers
Sounds like its a problem in the other end, if the machine can send and receviving faxes.
Check your phone lines from the wall to fax and ask the sender to do the same.
Posted on Nov 28, 2008
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
I receive 1 page of an incoming fax but then the next page is a fax call report saying comm error 232
Try this...
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
Mar 31, 2010 | HP LaserJet 3050 All-In-One Printer
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
FAX errors 345 346 and 350
HP.com has a web page for your product with all of the fax error codes listed and how to interpret them:
Fax Error Codes
Once the page opens, you'll have to scroll down until you find your error codes in the list. The codes in that section of the page don't seem to line up well. All of the codes have to do with the quality of service on the phone line. If the people you're faxing to are receiving all of their faxes except from you, I'd suspect your phone line may have a problem. Here's what I got from the list:
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Check with your phone company to see if their are any problems on your line. It looks like anything that even momentarily interrupts your phone connection will cause these errors. Good luck.
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Sharp fax machine
I keep getting a "Line Error" canot send or receive a fax. I have a SHARP UXB700
May 12, 2008 | Sharp FO 3150 Plain Paper Laser Fax
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
HP LaserJet 3150 All-In-One Printer Logo
221 people viewed this question
Ben Johnson
