Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag Dishwasher Latch Sticks
The latch on my Maytag Quiet Series 2200 dishwasher sticks. Any suggestion about getting to the latch (it's buit into the door) and what I should look for to repair it? Thanks- John
  • 1 more comment
  • Anonymous May 21, 2008
    It doesn't stick anymore...........now it is shut and won't open. Latch is up position as it should be when you open it but with no action??
  • Dale Dec 08, 2008
    My Maytag dishwaster MDBF550AWW door latch is broken. I would like to replace it myself but can't get the contol panel off. Do I have to loosen all the screws on the door or just the ones at the top that see4m to be holding the control panel.?
  • Anonymous Mar 20, 2014
    problem since the beginning - door won't latch shut. Repair man would "fix" it under warranty but I never saw how... any clues?
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Posted on Sep 12, 2007
SOURCE:
My maytag dishwasher door will not latch shut, and all of the lights keep flashing. What does this mean and how can I fix it? or will I have to buy a new one....?
Hi- Yes, these can be a problem. It is most likely the latch assembly as long as you don't see any obstructions and the racks are going all the way back. Sometimes you can carefully bend the strike (the part that sticks out from the frame) and get it to latch but try this carefully, you don't want to break that! The latch assembly is about $60. Part # 8193830. Good Luck
Sep 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
Nov 06, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher will not start
Maytag quiet series 200, all lights are on the selector panel, when I press start nothing happens. I have already replaced the door latch control last week....Now What?
Apr 27, 2009 | Dishwashers
Maytag dishwasher MDB7600AWW handle
Welcome
At the site below is the diagram for the door latch and assembly.
You can order there too!
W10130694 HANDLE, LATCH (WHT) (Series: 10) In-Stock $ 16.75 99003347 LATCH ASSEMBLY (Series: 10) In-Stock $ 21.80
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 25, 2008 | Maytag MDB7100AWB Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag quiet series 200 won't start
Does it help to push it more tightly shut...or fiddle with the latch.
Mine is not running consistently unless we push the door shut tightly. Others here also report problem with the safety latch causing this washer to quit. May have to replace the part.
Oct 18, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher latch
If it like mine, the latch is out of adjustment and you need to give it a whack with your hip to start it. If I adjust the latch looser, it leaks.
Oct 24, 2007 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
2,684 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
