Question about RCA P56940 56" Rear Projection Television
Bad focus I have a p56940 by rca and the focus is off. Is there a way to adjust it?
    Sergeant:
  • 280 Answers
Yes after removing the back you will see tree transformers on the main board. it has three adjustment controlls on it ... the top one is focus. most of the time if you clean the lenses and mirror that will clear up fuzzy picture problem but some times the coolant is low or contaminated in the projection lenses
Posted on Nov 28, 2008
Will not turn on makes thumping noise for a few seconds and than nothing happens
Short either in the audio circuit or the part of the power supply that sends power to the audio circuit.
Dec 09, 2012 | RCA P56940 56" Rear Projection Television
Showed shadows a few times, so I turned off and back on . Now it will not come back on.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 11, 2010 | RCA P56940 56" Rear Projection Television
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Focus
Focus control is on the Flyback there is 2 adjustments one is screen drive other is focus turn it untill you have clear picture.
Sep 03, 2008 | RCA F32450 32" TV
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Out of Focus
Yes most of all tv's have focus blocks or Flybacks with screen and focus controls on them. Some sets have it where you can do it with back of set attached and some you have to take back off to adjust. Either way you have to be very careful, because you are dealing with High Voltage and can harm you as well as your set. It will be marked Focus and the other will be screen, Scr. is what lights or Darkens a set. Do not move this unless it is needed. You will need a mirror or someone looking and tell you to stop.
Aug 24, 2007 | RCA MM36110 36" TV
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Jul 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 46" Rear Projection TV - Picture is Blurry and RED
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Dec 27, 2006 | RCA P46812BL 46" Rear Projection...
Misconvergence
Convergence on RCA P56940 chassis PTK195 can only be done by service center with RCA Chipper Check computer interface box. Sounds like possibly missing -15 volt or +15 volt supply to digital convergence circuit, bad i.c.'s U19503 or U19504. Supply voltages come from regulator supply transformer T19701 diodes CR19707 (-15 volts) and CR19709 (+15 volt)
Dec 22, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
