Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
When printing, the black ink barely works, acts like it is empty.
I have run the diagnostic, cleaning (deep and normal), calibration, even changed out the black ink cartridge (not even empty) and still the copies that are produced look as though they either have very little black ink or none at all. Any ideas? I have the Kodak 5500 EasyShare All-in-One Printer.
  • 1 more comment
  • renz_rn Nov 22, 2008
    i have the same problem. tried everything i can according to kodak support. all i haven't done is change the printhead. help pls!!!
  • dreed32001 Nov 29, 2008
    When I called Kodak, they sent me an entire printhead kit (printhead, ink, and paper). There was no charge for anything. Once I put in the new printhead, everything worked like it was supposed to.
  • P. Thomas
    P. Thomas May 11, 2010
    can you run a test page and report what you get?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Basically you have done most of the procedure for this issue, try resetting the ink then try again, for same issue call support for printhead replacement 1 800 421 6699
Posted on Nov 22, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Jun 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Light printing..need to clean
Depening on which printer it is , but normally all vendors include a system utilty with their printers to do head alignment, calibration and cleaning, some have what is referred to as a deep cleaning cycle as well, which does consume a bit more ink but does sometimes get rid of very light printing. If nothing else has changed in preferences such as print in high speed draft mode(which will give lighter than normal printing) then do a few cleaning cycles and possibly a head re-alignment.
Apr 15, 2009 | Computers & Internet
Banding
Try running a deep clean and after the clean, calibrate the printer. If that doesn't work, call kodak tech support, you may need a new printhead.
Sep 07, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
128 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
