I need to replace m7 diode on the board
SOURCE: I have a working chi flat iron but it broke at the
you can seek a local technician in your city..
SOURCE: My chi flat iron is
Try resetting it. Sometimes that can fix the problem. Make sure it's not a damaged cord. If it is, let me know and I can help you out with it. If it's not that, depending on how long you've had it, you can probably return it for another one.
SOURCE: Just bought it online and
Sorry Jason but they are not machine pressed. Remove the round "Chi" Logo covers at the hinge , underneath you will see 2 large phillip type screw heads.Take 2 large phillips screwdrivers, grip firmly and twist (lefty loosey) and with a bit of effort you will loosen them. NOTE: Put a rubberband or something at the open end BEFORE this to prevent the spring for doing what springs do when you remove the pin at the hinge. The pin is male/female type with one long side with a machined exterior and internal threads and a shorter bolt or screw side with traditional external circumferential threads. Once this is out and you take off your rubber band safety you can carefully remove the hinge spring. Note that one side of the spring is longer and that side goes on the longer half of the iron which should be the half with the switch. All the main business is on the swith half, so remove the four screws on cover plate (2) at top just below ceramic and (2) just above the hinge area. You may have to pry this apart but it shoud remove hinge end first then top. Remember to install it in reverse as it was removed. You will see a circuit board and (4) wires at the top. The inner 2 are for the heating element and the outer 2 for the thermal fuse. Get a multimeter and put it on the Continuity Check mode or Ohm mode. Touch one lead to one outer wire and one lead to the other outer wire. If the meter reads 0, the thermal fuse is open or burned up and it needs replaced before it will heat again. I posted my repair and replacement of a thermal fuse today on here. I did it for about 10 bucks! Hope this helps.
SOURCE: I have several "Chi" Flat irons that no longer
When the flat iron does not heat up, it is usually the ceramic fuse that is located under one of the heating elements. I fixed my daughter;s CHI flat iron for $1.97 with a ceramic fuse I bought at Radio Shack.
