Question about Maytag MMV4205 Microwave Oven
Possible door adjustment problem
I have a new Maytag MMV4205BAW - in fact, it was installed just last week. There seems to be a number of problem symtoms, all seem to be related to the door latching. To begin with the door doesn't seem to fit tightly. It's almost as if the latch doesn't completely latch. Quite often while running the door will slip open slightly. When this happens, the oven fan will continue to run, but it will no longer heat. The display says "close door". When pressure is applied to the top of the door, display reads "press start" and fan stops. When the start button is pressed the oven will begin operating normally, but usually the problem reoccurs within a minute or so. Another symptom is that sometimes when the door is initially shut, the fan begins to run before any entries are made on the keypad.
Is there a small adjustment to the door (or other item) that could cure these problems, or would it be better to remove the oven and return it for replacement?
  • Maytag Master
  • 9,098 Answers
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Or you can return it for replacement.
I would not suggest trying to fix this yourself since it's under warranty.
Posted on Nov 23, 2008
Maytag microwave turntable doesn't operate
Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
Double check before ordering...but ..
Here is the one you need:
Turntable Motor DE31 10172C
Oct 01, 2017 | Maytag Microwave Ovens
I have a maytag built in microwave MMV4205BAW from August 2006. The microwave runs but does not heat and makes a slight buzzing sound. It sounds like the magnetron needs to be replaced. If this is not...
From the description it is the magnetron, it will be expensive for the part alone, and keep in mind shops have different rates making impossible to give exact quotes, but I would estimate parts and labour at least $250.00 or more, if you decide to go with the repair make sure the magnetron is not a aftermarket product it will last about 6 months.
Jun 16, 2012 | Maytag MMV4205 Microwave Oven
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
Maytag MMV4205BAW not turning
Change the turn table motor part # DE31-10172B
Aug 18, 2011 | Maytag MMV4205 Microwave Oven
Display and touch buttons inoperative on MMV4205BAW Microwave Oven. Only abt 2 yrs old...
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
Feb 21, 2011 | Maytag MMV4205 Microwave Oven
How can I view installation Instructions on a Maytag over the range microwave MMV4205BA
It depends on your full model number:
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Dec 17, 2010 | Maytag Microwave Ovens
I have a Maytag mmv4205baw Microwave oven. It
the unit that creates the microwaves called the "magnetron" has gone bad, or the circuits powering the magnetron have gone bad. there really isnt a cheap way to fix it, and not a undangerous way to fix it yourself. if your really like the microwave and dont want to part with it, you can try finding a repair shop that will fix microwaves, but they will probably tell you it would be cheaper to buy a new one. sorry
Jan 15, 2010 | Magic Chef CMV1000B Microwave Oven
Microwave no longer heats, makes more noise than it did when it was heating. Microwave is a Maytag, model # MMV4205BAW. Thanks.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Nov 27, 2009 | Maytag Appliances Over-the-Range Microwave...
Exaust fan has weak suction on maytage mmv4205baw
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Need diagram of venting to install mmv4205baw new construction
Nov 04, 2008 | Maytag Microwave Ovens
Maytag MMV4205 Microwave Oven Logo
361 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
