Question about Rainbow E series Canister Wet/Dry Vacuum
Need to replace the power cord
I am trying to replace the power cord on my rainbow and I need to know how to get to the wiring. It looks like the top cover should pop off but I don't want to force it until I know that is what I need to do.
  • Anonymous Jan 02, 2009
    Yup, use a small screw driver to push the tabs down that hold the plastic windows on. As said above, pry them off (but carefully).There are three screws on each side; remove those and the top comes off. The power cord that comes with the rainbow is very thin and I'd recommend upgrading to 14-2, which is what I've done. You can get appliance cord from Home Depot or Lowes for fairly cheap. Buy a two-prong plug...and your good.
    Also, while you have the top off, you may want to check your motor filter and perhaps clean it. It should look like a circular automotive filter; in this case it can be washed clean. If it has platic feet on the bottom, you'll need to replace this with an newer version as this type is defective and will shorten the life of your motor (it happened to me).
    FYI: I rebuilt my E-series from ground up...and it runs better than ever.
  • 125 Answers
Pry out the clear plastic covering the Fins going around the body
Surprise no fins in there but there are some screws
Posted on Dec 16, 2008
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
Power cord leaks green oil
I suggest that you replace that corroding internally power cord. It may not be safe to use that power cord.
You can get your model information, at the bottom of your vacuum canister, from underneeth, where the water pan attaches to it.
It is probably a D3, or a D4
Thank you,
Ralph
Apr 10, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have a d4c rainbow vacuum, need help replacing the electrical cord
you have to splice them. Use crimp-on wire connectors (best), or threaded twist-on wire connectors. Do NOT just twist wire strands together and tape wires without using wire connectors . . . that is a NO-NO.
Jun 02, 2009 | Rainbow 75th Anniversary Canister Vacuum
Replace power cord
http://www.rainvac.com/schE1.pdf
Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Cleaning the flter on a e series rainbow vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=749568
Cleaning the filter on a e series rainbow vacuum
Posted by jonesjpc on Jul 06, 2008
This one does not have the tabs to depress as but has two screws in that area still doesn’t see how to get to the filter. Also I need instructions to replace power cord; On the E series single speed.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Rainbow E Series there really is no actual filter – the water is the filter for this particular vacuum. Before you remove the separator under the motor, place a newspaper or towel under the Rainbow without the water pan under the vacuum and then turn it on for a short period of time and spin the water moisture out of the motor and separator; then some of the maintenance is to remove the separator under the motor and clean that and then replace it. As far as replacing the cord there are screws under the Rainbow that need removal and then you can get to the end of the cord for replacement. The easiest way is to mark your wires and the cord will be much easier to replace otherwise check the owner’s manual for cord replacement or check with your local vacuum cleaner dealer in your area or to cal the cust serv @ the Rainbow factory for questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Jan 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
There is no reset button, but some of those old switches are very touchy . . . if there was some  corrosion, you may not have a good contact (was enough of the new wire insulation stripped away, before putting it into the switch) . . .
I prefer splicing, rather than going all the way to the switch  . . its just a matter of cutting out the old cord and splicing in the new cord in a convenient spot up in the motor compartment. . . a Rainbow purist would run the new cord all the way up into the power on/off rocker switch that's built into the top of the handle and then wire the new cord in there, directly at the switch . . . that way means no splicing . . . I've done it both ways, but I prefer to splice and use wire connectors inside the motor compartment . . . because going further, all the way up directly into the on/off switch just to avoid splicing the new cord in requires taking more things apart . . . and risks screwing up the power switch . . . that's not worth the extra time and trouble, IMHO.  (This from someone who has dismantled and refurbished over 200 D4C and SE models)
Jul 26, 2007 | Rainbow 75th Anniversary Canister Vacuum
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
164 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
