Question about Sharp MX-2300N Color Copier
Sharp MX-2300N trying to send image to email address gives error
Sharp MX-2300N is setup on network with static ip address, we are trying to send a scanned image to an email address. Error - Selected servers are not found. This worked before we put in a new firewall a Watchguard Firebox x Edge. We have opened all outgoing ports and the tech who installed has run out of ideas. Local Sharp tech has called in outside techs and they still have no answer. The other function of sending images to a local server works, so it's connected to the network. Any ideas would be helpful..
Thanks
  • Mike S
    Mike S May 11, 2010
    What is the exact code you are getting?
    When did this start happening? Is this a newly installed machine?
    What ISP are you using...? I have had many problems with Embarq…
    Are you using an xchange Server... is it configured to send SMTP mail
    Have your Techs tested the Mail relay?
    Is your ISP blocking port 25?
    Sometimes the time out is not set right; changing the time out will make it work,
    Default time out is 20..
    Then there is user authentication.. is that set correctly?
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Posted on Dec 19, 2008
How can i get where to put network IP address
this can be done through both, the computer and the printer control panel, under wireless settings where you mention the ip address.
Call 1-877-805-1027 for Toll Free expert help.
Nov 17, 2015 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color scanner can't find network
Drivers are for print functions only (or twain scan via USB). Check for bad cable, port, or jack. Could be another device on the network is being handed the IP of the copier via dhcp (or vice versa) can you ping it from a workstation? I have also seen the dell network assistant utilities on some dell workstations cause issues like this.
Jan 11, 2013 | Sharp MX-2300N Color Copier
How do you select an IP address of a sharp mx-2300n
To set an IP address, go to the system settings page. Enter admin mode (password if unchanged should be "admin") on page 2 select network settings and then ip address settings. Input your required info and switch machine off and back on when instructed.
I hope this is the info you needed.
Good Luck
Oct 11, 2010 | Sharp MX-2300N Color Copier
Scanner user IP address changes
Print a configuration page and enter the machine IP in the address box. That will pull up the machine settings then most likely look in properties and go to what you want to change.
Jul 29, 2010 | Sharp MX-2300N Color Copier
We just got an MX-2300N and are trying to set it
I had the same issue the other day when installing one of these machines.
I find it alot easier to enter the details into the machine from it's web interface if you aren't already.. (Simply open your web browser and navigate to your copiers IP address).
If you ping the domain name of your mail smtp server and just get the servers i.p address and enter into the smtp box it should work. The particular one i used didnt need authentication either, give it a whirl and see how it goes.
Jul 15, 2009 | Sharp MX-2300N Color Copier
Sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Jun 30, 2009 | Sharp Office Equipment & Supplies
OurSharp MX 2300N printer is used as a share printer, wont print
Chances are when you changed ISP's that network IP's changed and your IT will need to put one into your copier that's compatible with your present network setup.
You'll also need to make sure all work PC's have their printer drivers changed to reflect the new IP address for the copier, or it won't print.
Jun 17, 2009 | Sharp MX-2300N Color Copier
CE00 Error code
CE-00 means the copier cannot find the computer or server it's directed to scan to.
The usual cause is that the IP address for the scan destination has been changed by DHCP and the connection info has not been updated in the copier.
To resolve, reboot the destination workstation or server. Or, right-click on the Network Scanner Tool icon in the tray, select Automatic Profile Update, and click on Update Now.
If the scan profiles were created in the webpage and not through Sharpdesk/NST, make sure that destination names and/or IPs have not changed in the profile.
If you are using DNS name resolution instead of direct IP addressing, you must be sure that the DNS server IPs are correctly entered into the web page.
Hope this helps!!
May 22, 2009 | Sharp MX-2700N Color Copier
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp MX-2300N Color Copier Logo
4,023 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
