Question about Dell Axim X5 Pocket PC
I have on scree this message: align screen tap the target firmly and accurately at each location on the screen.the target will continue to move until the screen is aligned . so i do it but the result is o. so help me please
98% of all Axim X5's with screen alignment problems can be fixed
using these instructions. The design of the unit eventually wears
through the ribbon connector to the screen, and causes it to be
grounded, which gives you the sympton of always needing alignment.
A 3mm piece of electrical tape will usually eliminate the problem
for several years. This is fairly easy if you have tiny screwdrivers,
but I assume no responsibility if this doesn't work or something breaks.
1. Backup data with ActiveSync's Backup/Restore function under "Tools"
on the desktop PC. If you use Vista's Windows Mobile Device Center,
it's under Mobile Device Settings-->more-->Backup and Restore.
If you use a browser, delete the temp cache, cookies and history files.
2. Remove main battery to uncover two screws, and remove backup battery
and any memory cards or blanks.
3. Carefully unstick the four rubber feet on the back, uncovering four
more screws.
4. Very slowly unstick the two rubber side panels, making sure most of the
sticky stuff stays on the rubber grip.
5. Use a tiny phillips screwdriver to take out the six screws on the back.
6. Carefully separate the front and the back halves of the case. A little
prying with a tiny flat screwdriver might help, especially at the bottom.
The half covering the top might have to be moved further up so the top
will clear the headphone jack. The front should have only the speaker
wire connected to it, which can easily be pulled up and off.
7. Locate the small mylar cable at the bottom of the front of the screen.
You'll see a nick or dent in the insulation right over the left wire.
Take a tiny piece of electrical tape slightly larger than the nick and
put it on. Don't push too hard on the cable.
8. Put the case back together, reversing the directions above. Plug the
speaker wire back in with the black wire on the bottom, red wire on top.
Put the top half back on starting at the top of the PDA by putting the
dark plastic part over the headphone jack first. Put the bottom half
back on starting at the bottom of the PDA near the sync connector by
putting the two easy-to-break snap-in nubs in place first.
Posted on Dec 09, 2008
How to align my screen on samsung giorgio armani 520
help me :) :( ''align screen : tap the target firmly and accuratelyy at each location on the scree, the target will continue to move until the screeen is aligned''
Jul 22, 2011 | Giorgio Armani Samsung P520 Cellular Phone
Can't update dutty rom to latest version and also windows update my phone is htc 8900 tilt--kaiser at & t
woh guyz ..can u help .guyz ,,
tap the targey firmly and accurately at each location on the screen the target will continue to move until the screen is aligned\\
...add me if you want to help me ..
.yahoomail : enrique_baguio@yahoo.com
.facebook : ejbaguio@yahoo.com\
.twitter account : enrique_baguio
May 15, 2011 | HTC Tilt 8900 Smartphone
Cant align screen..help plz..show me the way..xperia x1
my phone showthn screen and masage tap the target firmly and accurately ateach location on the screen .The target will continue to move until the screen us aliged
Feb 02, 2011 | Sony Ericsson XPERIA X1 Smartphone
My htc p3400i mobile donn,t show screen only see align screen?what i do
showing align screen written in under
tap the target firmly and accurately at each location on the screen. the target will continue to move until the screen is aligned._1037.jpg
Jan 27, 2011 | Computers & Internet
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
Imate JAq3 USB Drivers for windows XP
You just need the Microsoft Active Sync From the microsoft website, nothing else.
Please rate if this solves your problem...
Jul 13, 2009 | i-mate Computers & Internet
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
Align screen
Align screen, message : Tap the target firmly and accurately at each lotation on the screen , the target will continue to move until the screen is aligned
Sep 01, 2008 | i-mate PDAL Pocket PC
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
Dell Axim X5 Pocket PC Logo
236 people viewed this question
Alun Cox
