Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker feeding too much water and overflows
GE Profile Refrigerator TFX24PF
The Ice maker is feeding too much water and overflows water into the bin and creating globs of ice.
I assume there is an adjustment inside the ice maker to adjust water flow. I am sight impaired and am having trouble seeing how the cover comes off the ice maker to get to the adjustment.
Can you help with removing the cover, and further help with the actual adjustment once the cover is off.
Thank you,
Ed Z
  • 3 Answers
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Posted on Apr 03, 2009
  • 89 Answers
There is nothing wrong with the icemaker if infact it is "overflowing". Be carefull not to confuse "overflowing" with the ice maker leaking. Nevertheless, if the icemaker is "overflowing" with water and is still making "BIG" ice cubes then you need to replace the water valve located behind the refrigerator in the compressor department. Hint: it is blue.... Also, you may want to hire an appliance person to do this for you. Should cost around $200 to have fixed.... goodluck..
Note: If you determine that the icemaker is not "overflowing" but instead is "leaking" water then you need to replace icemaker instead of water valve. One more tid bit of information for you, Its bad when I can look at the model number and know EXCATLY what your fridge looks like! This GE fridge will give you cooling problems in the near future. Turn off during thunderstorms, too many flicker's of electricty will burn up the computer board on your fridge costing you around $400 big ones.. More from my website on GE at: http://www.houstongofarappliancerepair.com/Refrigerator.html
Posted on Dec 02, 2008
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser grill
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | GE Profile PSW26P Stainless Steel Side by...
Control panel
Its faulty control panel, needs to be replaced.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
How to remove ice maker on ge profile pfss6pkwbss
You would first have to distinguish between if the tray has a crack in it or if the water valve is not closeing which would mean you would need a new water valve. Most all ice makers are held to the freezer wall by 3 1/4" screws you would unscrew these screws and unplug the power connector and remove the ice maker from the unit. Fill the ice tray with water and see if you do have a crack in the tray which is not as common as a water valve allowing to much water to go into the ice tray makeing it overflow. If you have any further questions message me back I await your reply.
Thank you,
Rick
Jan 19, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
With old maker plugged in the water comes in
Unplug the wires to the ice maker solenoid on the rear of refrigerator. It is where the water feeds into the back of the refrigerator.One side goes to water dispenser and the other side goes to the ice maker. You can follow the water pipe up the back to freezer. Sounds too much like your dual water control valve needs replaced. If your model number is correct above your post the part number is WR57X10032
If you need more help please let me know, Thank You, Sea Breeze
Oct 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Jun 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,579 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
