Question about Shredder 1052 (Cross-Cut)
Shredmaster crosscut 85x jam
It is jammed and trying the reverse and forward does not work. I got this from a friend and I have oil and lubrication sheets from an old shredder long gone... but do not know where and how to lubricate this particular model and if I should
thanks any and all help would be greatly appreciated since I would like to give this back to my friend in working condition.
  • 48 Answers
SOURCE: Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Posted on Jun 04, 2007
JayBlair
  • 328 Answers
SOURCE: Brother Intellifax 4100 squeaky sheet feeder
The doc feed asm needs to be rebuilt. Only white lithium grease is used to lube the gears and avery light oil on the shafts. All parts are available from brother. I can get the parts if you have trouble obtaining them. It is relatively easy to rebuild and I charge in my area of Clearwater Florida, about 100.00 parts and labor.
Posted on Aug 01, 2007
fellowesrep
  • 102 Answers
SOURCE: Royal 85X 10 Sheet Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
goalie39
  • 469 Answers
SOURCE: How do I lubricate a Aurora AS702MX shredder?
two ways, first take a light oil (3 in 1) and scribble a pattern on a piece of paper and pass it through the cutting heads do this a couple of times, this can be done as you shred just put a little oil on papers you are about to shred from time to time.
second, if it is a light duty machine, with plastic parts, then pass some waxed paper through the shredder to clean and lube the heads, this also works for your 3 hole punches.
Posted on Apr 13, 2009
  • 250 Answers
SOURCE: Shredder doesn't want to shred in forward gear,
Shredders became popular when the identity theft thing started happening and to save money they stopped making them with quiet, powerful induction motors and now it's almost impossible to find a consumer model without the poor quality loud motors that don't have enough to power to operate the machine once it's a little dirty. Anyway, unplug it, and you're doing this at your own risk, take the shredder off the trash can or its own waste bin and turn it over. If it's straight cut shredder you will probably be able to see the slot where the shredder paper exits the blade area. If it's a crosscut shredder there might be a door that will close over the blades to cut you from getting cut. Respect that, but open this door, and see if there's bits of paper jammed up around the blades. Wear some protective gloves and use pliers or some kind of tool to dig out the compacted trash, being careful not to damage or bend the blades. Now you should pick up some shredder oil from your local office store, or see link to order. Follow the instructions on the oil, and this will make your shredder run with a lot less stress. This is only a temporary fix however. In a couple weeks or months you will have to do this again. It's all part of owning a paper shredder. If you like it that much, look into buying a nicer model. You totally get what you pay for with a paper shredder.
Shredder Oil: http://www.officedepot.com/a/products/285661/Office-Depot-Brand-Shredder-Oil-4/?cm_mmc=Mercent-_-Google-_-Shredder_Supplies-_-285661&utm_source=Google&utm_medium=CPC&utm_campaign=plusbox-beta&mr:trackingCode=7646DB1A-EC81-DE11-B7F3-0019B9C043EB&mr:referralID=NA
Posted on Sep 18, 2009
Paper jam both forward and reverse are not shredding it is a clump of papers and I can't get it lose
Sound like a serious jam up. Try a sharp small screw driver to flick out jammed paper and try rotating by hand. Caution ensure it is unplugged and use gloves to protect from sharp edges. With the clump of paper try a LITTLE water to soften the clump. Good luck.
Aug 25, 2013 | Royal 1840mx Crosscut Shredder
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
I have a paper jam in my shredder. How do I fix this?
Theory is that there should still be some paper sticking up that you can get a hold of.....switch the machine into reverse while trying to pull the paper back out.....if you manage that and it is still working make sure you put some shredder oil into the cutting blades and only run the machine at about 70% of its max. sheet capacity to avoid future jams and extend machine life.
Aug 30, 2010 | Royal 85X Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
JAMS...DOES IT NEED OIL?
You should occassionally lubricate any x-cut shredder, just put some shredder oil on a sheet of paper ; a big "s" pattern of oil will do then shred the sheet of paper to get the oil down into the cutting shafts.
Aug 07, 2009 | Royal 85X Shredder
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
My GBC Shredmaster 2260X is jammed and I can not clear it. The teeth try to rotate when stimulated but something is jamming it. Where can I go for service? I am in murfreesboro, TN.
you can do it yourself!! it take a little bit of time and patience. do it in an area that you can clean easily. take off and unplug the top, turn upside down, get a flat screw driver and start removing all the papers in the teeth area. from time to time you will need to put it bank and turn it on and make it go forward and reverse.
Sep 15, 2008 | Office Equipment & Supplies
Shredder 1052 (Cross-Cut) Logo
63 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
