Question about iRiver Audio Players & Recorders
After a few minutes the scroll button of my iriver H10(5GB) starts to scroll down of its own accord.The music is still playing but can't be heard,and scroll button is still clicking. Ray
I don't know yet if I've solved it or not. It has been playing for approx.30mins. without a problem, but
all that I've done is recharge both of the batteries,( which were not showing empty) . What is the life
span for one of these batteries, and why should the music carry on?
Cheers, Raymill.
Posted on Nov 22, 2008
IRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Jul 24, 2010 | iRiver E150 (4 GB) MP3 Player
Scroll not functioning
Back up your stuff and try a hard reset. Sounds like the software is glitching on you.
May 09, 2008 | iRiver H10 MP3 Player
Iriver clix gets static-y after a few minutes
Hello Cart, I am sorry to hear that your Iriver Clix Gen 2 4 gb video player recieves enormous amounts of static that makes it unaudible after a couple minutes. I see that you have eliminated one of the factors of static by upgrading the firmware, but unfortunately the firmware is only related to booting up, and loading your movies/music. If the static is coming from the speakers, you may not be able to fix it, unless you open up your Iriver Clix, which I recommend you not do, due to that it will void your warranty. The Static may be caused due to excessive geforce or impact to your device, causing the wire's to be loose. If the static is coming from the speakers, I would recommend you to return it to the manufactuer or return it back to the store. If the static is coming from the 3.5 mm plug, try a different pair of headphones or earbuds, make sure it is fully plugged in, I would also recommend you to return back to the manufacturer, or return it back to the store. -Tom Smith.
Aug 26, 2007 | iRiver Clix Digital Media Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
I river s 10 not workng
Not sure of the real answer for this but I use my Iriver like an external hard drive. I just drag and drop my music on without using the Iriver software. Have not had any problems yet.
Aug 12, 2008 | iRiver S10 2 GB MP3 Player
Music on e10 not actually there and iriver not working..
go into the extras menu and click on browse menu, then go to music and if in luck your music should be there ready to play.
Jul 29, 2008 | iRiver E10 Digital Media Player
Down button
i cant download music in my iriverclix
Jun 12, 2008 | iRiver Clix Digital Media Player
Iriver s10 problem
there is a 'reset hole' next to the power on switch - you need a pin to push into the reset hole
I do not use the software that comes with the S10 - it always wants to go on to the internet and re download itself. If I want to copy music over I use windows explorer and copy MP3s into the music folder
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Jun 07, 2008 | iRiver S10 2 GB MP3 Player
Iriver h10 (5gig) not playing music (firmware 2.53)
install version 2.51 firmware and run mtp updater this can be found on iriver site www.iriver.com-support-ask.asp
Jan 21, 2008 | iRiver H10 MP3 Player
IRiver keeps loading and loading and ...
Just a thought, try removing the battery, then holding the rest button in for about 15-30 seconds, release it, then re-attach the battery, if that don't work, try removing the battery, then re-attach the battery while holding in the reset button, then release the button after about 15 seconds. Konqueror?, That's a Linux based file manager/internet browser, is it on your PC or the iRiver? If it's on the iRiver, then the operating system is more likely Linux based, and removing the battery then re-attaching the battery while holding down the reset button, should!!! (not everything works as it should) reset the machine.
Jun 18, 2007 | iRiver H340 MP3 Player
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
