SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
SOURCE: no display light on my casio ctk 496 every thing else works
Sorry, but many of the low end keyboards do NOT have backlights. This is especially true of those that have the capability of running off batteries like the CTK-496.
The display in this is a reflectance type that needs ambient lighting to view.
SOURCE: NO power to my Casio CTK 671
OFTEN the power connector in the synth get broken from the circuit board connections.
ALSO verify the adapter is actually putting out the correct voltage or slightly above it..
SOURCE: my casio ctk-710 does not work with the power
There is a contact switch in the power connector that must be making for batteries to work... I suspect that either the soldering of the power connector or possibly a broken circuit trace to the power inout connector may be the problem.
SOURCE: I can´t find CASIO CTK-810
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
