Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony lcd tv picture starting to fade
Tv now takes longer to show picture once the unit is powered up, and once it is on the colors appear to be faded,not as vivid as they once were. the unit is four years old. will another lamp fix the problem and is this a cost effective measure
    Genius:
  • 1,139 Answers
Hello oilreddye,
This sony (KV-36FS120) is a flat screen CRT type Television not LCD. However the problem you are describing sounds like a CRT problem. I posted this before and I hope it is helpful to you,
This may be a CRT problem. From what it sounds like i.e. dim picture, colors not bright. If you have a background in electronics I would tell you to check the voltage levels on the CRT pins and compare them to the values on a schematic, however if you do not have a background in electronics, I would suggest you taking the TV to your local TV repair shop and have them troubleshoot your problem.
Here is a possible list of things that might be wrong:
1) CRT going bad (The shop can try CRT rejuvenation if needed)
2) High Voltage on the anode not at proper levels (The shop can check this with a HV probe)
3) Video output levels low (The shop can check the voltage and signal levels on the CRT socket board, and on the video amplifiers).
These are the three primary possible issues.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 22, 2008
My Samsung TV color fades out after about 30 seconds.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 28, 2014 | Televison & Video
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
We have a sharp lcd tv. it is 2.5 years old. The
the lcd tv hhave somethig like a bulb and after a period of use that bulb must be changed. take the tv on service. the service man wil see what is the problem most accurate.
Feb 14, 2010 | Sharp LC-32AV22U 32 in. LCD TV
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
32''LCD TV Polaroid FLM-3201 - picture crackling and color fading
Sounds just like a loose solder connection. The trick is finding it. I would start with the microchips and the large transformer. Otherwise, it could be a capacitor starting to short out. I would give both options a 50-50 chance to be the problem.
Nov 13, 2008 | Televison & Video
Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Apr 10, 2008 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
291 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
