Question about Canon Office Equipment & Supplies
I have a bottom feeder paper jam but cannon see the paper to remove
    Novelist:
    Scholar:
  • 70 Answers
Most bottom feeder printers also have a roller system on the back of the printer that pulls the paper up and through. Usually, if the paper is not visible, it is jammed in that back set of rollers.
Look on the back of your printer. Is there a bulge on the back? Does it have a latch or obvious set of buttons on each side? Try to push or pull the latches to open this compartment. The paper usually is wadded up inside this.
Would like to help more but don't know which model of printer you have. Please respond and I can be more specific.
Posted on Nov 21, 2008
CANNON MODEL D880 TOP FEEDER JAMS WHEN TRYING TO MAKE MULTI COPIES AND/OR FAXING...HOW TO CORRECT THIS?
Check to make sure that the rollers are in good condition inside the top feeder.
Also make sure that there is NO object or anything that the paper is hitting against by manually feeding the paper and carefully observe the paper path
May 03, 2011 | Canon Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
    Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
    Feb 02, 2010 | Epson Office Equipment & Supplies
    Cannon pixma ip 4600 error code 5700 - paper jam
    The error code 5700 is the sensor error.Replace the sheet
    feed unit and then adjust the timing of the paper feed gears.
    Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
    Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
    Please try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 09, 2009 | Lexmark T644 Laser Printer
    Blocked Feeder
    unplug machine and remove catch bin and reach under and pull jammed paper from the bottom and the top ..Good Luck
    May 02, 2009 | Office Equipment & Supplies
    Doc. feeder jam, after paper removed completely
    HP LaserJet 3030 All-In-One Printer
    Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
    Paper pulling to one side
    check the paper feeder if there are things blocking one side of paper loading.if so, remove it then try printing.
    Jan 09, 2009 | Canon I960 InkJet Photo Printer
    It says the paper is jammed, but there's no paper in it!!
    This is an awesome printer. Did you know it can duplex (print on both sides of the paper) automatically? The jam "could" be in the duplexer on the back or, the duplexer unit isn't locked into place.
    Unplug the printer and open the rear door, check for visible paper jam, remove, close door.
    There's also access to the feed mechanism from the bottom of the printer.
    Unplug printer.
    (1) Remove the Cassette. (paper tray on bottom of printer)
    If the paper is loaded in the Auto Sheet Feeder (on back of printer), remove the paper from the Auto Sheet Feeder and close the Paper Support.
    (2) Stand the machine with the left side down.
    (3) Slowly pull the jammed paper out while pulling the green cover toward you.
    Caution
    Set the machine back to its original position immediately after removing the jammed paper.
    (4) If any paper is sticking out of the Cassette, reload the paper in the Cassette.
    Reload paper in the Auto Sheet Feeder, if necessary.
    (5) Insert the Cassette into the machine.
    (6) Press the OK button on the machine.
    Some of these instructions were copied from the online/downloadable printer manual from Canon's web site: http://www.usa.canon.com/consumer/
    Feb 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    53 people viewed this question
    old marine
    old marine
