Question about Brother MFC-9420CN All-In-One Laser Printer
Magenta streak running length of paper
There is a bad spot on the magenta toner cartridge TN 110 - is there a way to clean the cartridge? It's not close to being empty so I really don't want to buy a whole new cartridge.
The model is Brother MFC-9840CDW
Any suggestions will be greatly appreciated.
Thanks,
Misty
  • jjpup Mar 07, 2009
    Only my magenta toner streaks, too.  That's odd and cannot be just a coincidence.
  • 4 Answers
Have you tried cleaning the corona wire?  You can also use a cotton swab and clean the drum.  Just be sure to unplug the unit from the wall and allow everything to cool down.
Posted on Dec 02, 2008
  • fixitden Apr 01, 2011
    Cleaning the Corona wire is the first thing to try. If this does not work look at the drum on the cartridge. I noticed streaks on mine. The streaks lined up with the streaks on the printed paper. I took off the wiper blade which resulted in a mess of spilled toner. (I thought I was being careful and shook the toner away form the drum but it did not shake away. What I sas was a rotary stiring/distibutor rake with lumps of toner in the rake. I cleaned the wiper blade repaceand it still streaked. I noticed that shaking the cartridge and turning the driver gear that turns the rest of the gears with a large flat screwdriver helped some. (note turn it clockwise only because I turned it backwards on a xerox drum broke a flap). Seeing the inprovement I filed a driver rod and turned the gears at about 2 rps / 120 rpm for about 5 min and the drum had a even coat of toner and no more streaks when using it. ( PS reset your toner left clock.)
    If anyone find a website that shows the proper names of the parts and/or how these parts work please add the website.
Uneven color printing...magenta only on sides of photo...not in the middle
Definitely a faulty cartridge. It is probably a build up of toner on the doctor blade or a deformed doctor blade.
Nov 14, 2017 | Brother HL-4070CDW Printer
My HP 4700d is printing magenta streaks.
Run a PQ test. On the control panel, go to diagnostics and then find the PQ test. This will print a quality test that will reveal if you have a bad cartridge, which is the most likely cause of magenta streaks.
May 06, 2011 | HP LaserJet 4700DN Printer
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Hp 4650n
There is not clean cartrige button.
If you want you can try to remove the cartridge and clean it with a paper towel, and see if that helps get you to 300 more sheets, if not I would replace it.
Angela
Aug 12, 2008 | HP LaserJet 4650 Color Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Apr 28, 2008 | Office Equipment & Supplies
Pirnting quality issues
That does look like a bad magenta drum, But let me look up some other items and I will get back to you.
Feb 25, 2008 | Xerox Phaser 7300DN Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
581 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
