Question about Garmin GPS
I bought the garman nuvi350 aaand there were no instructions. I,m having trouble getting the base put together
  • Garmin Master
  • 2,130 Answers
There is a copy of the manual in color on the unit's directoty in PDF form. Use your USB cable to read it and print it.
- Jim
Posted on Nov 21, 2008
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Assembly instructions for dw7350 mobile base
You are correct...the base is not pre-assembled as stated in the instructions. However it is a very easy task. The four base parts slot together in a fairly obvious way. The bolts to use are actually packaged separately and marked as "Bolts for Base". There are four bolts in total. One bolt goes in each corner of the base assembly. I put my bolts through from the bottom with the nuts and lockwashers on top. I did this to minimize the ground clearance although now that it is assembled it probably wasn't necessary. Once the four base pieces are together you can follow the instructions as printed. BTW, when bolting the four upright channels to the base, two of them use the same bolts as the ones holding one end of the "U"-shaped wheel supports. The instructions didn't mention this. It is also fairly obvious. In the end, no problems putting this extremely sturdy stand together. I'm glad I bought this to go along with my planer!
Feb 26, 2013 | Dewalt DW7350 Portable Planer Stand
Putting the base together
When i put my Fieldcrest Armoire together the base connected fairly easily to the other 3 pieces. Are you sure that you followed the instructions very carefully and haven't mistakenly mixed up some of the wooden pieces? I would re-read the instruction manual very carefully again and if you are sure you've followed the correct steps, you can contact the place where you bought it as maybe they gave you a wrong piece. Good luck.
Sep 29, 2012 | Foremost Fieldcrest Armoire - Espresso
I bought a evenflo aura stroller from someone so i don't have the instructions. I took all the covering off so it could be washed and now i am having trouble putting it back together and getting the screws...
Hi Fumbling
You can try this Link, it will lead you to a .pdf manual to save/print/read.
Explanation about washing/detaching and attaching the fabric on page 9 "removing the seat pad".
Hope this will help you out!
Kind regards
Apr 21, 2011 | Evenflo Aura Traditions Travel System...
Instructions to the Evenflo Jenny Lind Crib
Go to https://plweb.evenflo.com/replacement_parts.aspx
Enter model number and year of manufacture.  (There is a help link on the page to get that info if it is not obvious.)
May 27, 2009 | Evenflo Jenny Lind Crib
Need new instruction manuals garman GPS map492 sereal #70405694 & Garman Fishfinder 400c sereal #12c005161 thanks milton
you should be able to get them from garmin website and download them in PDF for free
Jan 26, 2009 | GPS
Instructions for jenny lind crib
Hi i am just selling this crib on ebay. The instructions for mine are on the base?
It is really easy to put together.
Email me if you are still having problems.
Thankyou Amy
Jan 23, 2009 | Evenflo Jenny Lind Crib
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
GPS Logo
56 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
