Question about Motorola Mobility RAZR V3
My nokia n70 wont turn on
I have a nokia n70 i'v had it for about 2 years and i just found it again coz i lost it lol and i'v charged it for 3 hours so far and it wont turn on for some reason can any 1 help me
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them fix it for you
Posted on Dec 28, 2008
Hiw do I fix my off line Nokia N70
I jus purchased N70 3 days ago...n faced the same probs...
All u need to do is to switch d phone off.....Switch it on again ..it will ask....
Switch to OFFLINE mode ....SAY "NO"
It will wrk....
coz it wrked for me..
May 15, 2014 | Cell Phones
Nokia N70 no signal problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 10, 2013 | Nokia N70 Cellular Phone
Low battery
sir the nokia n70 comes with BL-5C battery this batter has a complaint it will not cover 1 year lifetime. so the best way is to buy a new BL-5C battery and charge it initially for 8 hours continuously..
Dec 06, 2010 | Nokia N70 Cellular Phone
N70 found dead
Your phone is not dead yet. So nothing to worry. Try the below combination ,please follow this sequence:
PRESS the buttons green,*,3, power combination (until you get it to work).
- Turn off PIN code requests.
- Charge the phone fully.
- Turn off the phone.
- Remove the memory card (not really needed, but I usually do it to be on the safe side).
- Put the phone on a table (easier to press the keys then, in my opinion).
- Press the three keys and keep them securely down and do not release.
- While the keys are still down, turn the power on.
- Do not release the three keys .
Hope this helps
Mar 16, 2010 | Nokia N70 Cellular Phone
Nokia N70 restore to default how to get data back up
if he has successfully restored your phone settings it impossible to get you data back. But hoping for the best just go to your messages- settings-others-memory in use and select phone memory. its actually not possible for restoring the phone just playing with it or pressing buttons . it seems like his curiosity killed the cat. all my condolences with you.
Jun 08, 2009 | Nokia N70 Cellular Phone
Nokia n70 wont turn on.
it sounds like its been stolen or hardwear is faulty
May 21, 2009 | Nokia N70 Cellular Phone
Nokia N70 Power Problems
my fone is charged...all of a sudden i switch off and then when i switch it on..all it shows is nokia nothing else...i have a N70 ..please help me
Mar 07, 2008 | Nokia N70 Cellular Phone
My N73 is not charging
try to replace ur charger, coz charger not compatible to your phone.
Feb 07, 2008 | Nokia N70 Cellular Phone
My Nokia N70 is no more ringing
Check your phones software version, input *#0000# on your phone.
Then go to:
http://www.nokia.co.uk/link?cid=EDITORIAL_799358 on your PC.
The code required is under the battery, it looks like this, 0522157
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Jan 18, 2008 | Nokia N70 Cellular Phone
N70 lost signal
reset your phone it might work
Nov 30, 2007 | Nokia N70 Cellular Phone
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
