Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer is leaking
Our washer is leaking and its not coming from the hoses. we opened up the back of the washer and let it run and suddenly there was a long plastic bag leaking inside the washer what is this thing. the model number is actually gvw9959kq1
    Problem Solver:
  • 17 Answers
Check the boot hasnt split in the door well
Posted on Nov 21, 2008
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water is coming from under the washing machine not out of the hoses, where could it come from?
There might be two possible reason for that.
it might be coming form the tub itself passing through the rubber seal of your plastic rotator(the big wheel inside the tub)
the other thing is in the junction of the hose the tub.
try to open the back of your washing macjine where you can get an access inside the wheel and the junction connector, from there you will the cause of the leackage. try to put some water while looking at so you can see where the water is coming out
Nov 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool clothes washer model no LSQ9244EQ, S/N 2593319. IT LEAKS HOW DO YOU TAKE THE BACK OFF OR THE CABINET OFF SO ONE CAN SEE THE SOURCE OF THE LEAK?
The back does not come off on these model washers. You will need to remove the washer exterior cabinet in order to sufficiently locate the source of your leak. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components. NOTE: Its a good idea to run a small amount of water in the tub PRIOR to removing the casing in order to get a better idea of where the leak may be coming from. The washer will not run without the lid switch plugged in, so fill about 1/4 full and shut the washer off before disassembling everything.
I know you replaced the drain pump, but did you verify if the hoses were good? Check both the hoses on the pump to ensure they do not have any cracks that could be causing the leak.
The water inlet and dispenser hoses are located along the back. Check for cracks and loose clamps.
To get the cabinet back on the washer, follow these steps:
1, With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Some other things to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the are UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak. Read through everything thoroughly before beginning any repairs. I hope this information is helpful.
Sep 11, 2009 | Washing Machines
Water leaking from machine
Sep 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is running out inside bottom of mechine
If the washer leaks only during the fill cycle, check these:
  1. Air gap device: It is a small device found on most washers to prevent the wash water from from being siphoned into the household water supply. It is located either midway along or at the the end of the black rubber hose that comes from the water inlet valve It is usually made of a translucent plastic. If it is deformed or cracked, you need to replace it.
  2. The tube: It is a rubber tube that runs between the water inlet valve and either the air-gap or the inlet spout. If it is broken, it can cause a leak.
  3. Inlet spout: Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If broken or loose, it can cause a leak.
During the drain and spin only:
  1. A washer that leaks only during the spin cycle often has a leak in the main drain hose. Check the entire hose and correct any problem you can find.
All the time:
  1. Hot and cold water fill hoses: Check the hot and cold hoses from the household plumbing. If either hose is leaking, tighten or replace it.
  2. Main tub seal: It is located between the transmission and the outer tub. Open the the machine's main access panel while the machine is full of water with a small amount of detergent. The leak appears at the underside of the outer tub, at or near the center.
  3. Pump: You can probably see the leak when the tub is full of water. If it leaks, replace it.
  4. Outer tub: Steel or plastic outer tubs can rust, split or be punctured. Consult a qualified appliance technician if it is the culprit.
Aug 22, 2009 | Speed Queen Washing Machines
Leaking from underneath. Doesn't appear to be the incoming hoses or connections or the drain.
Have you checked the drain pump? These washers are notorious for developing leaks with the pump. To inspect thoroughly, you will need to remove the exterior case of the washer. Just follow these steps:
Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. The pumps can develop small cracks and begin to leak. If this is the case, the pumps are not serviceable and must be replaced.
Check the tub seal. The seal in the center of the wash tub. If the seal develops leaks, you will notice water track marks on the transmission and a puddle under the center of the wash tub.
Check the the for cracks. Although it is not common, I have seen stress cracks develop on the exterior wash tub, causing leaks. The tub will have to replaced if this is the case.
Check the air dome hose to make sure it is still attached and not leaking. It is a small plastic hose that runs from the pressure switch in the console to the lower right hand side of the wash tub. If the hose comes loose of develops leaks, the washer will begin to leak as it fills (usually about 1/3 of the way full).
To reinstall the case, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
NOTE: Run some water in the tub about 1/3 of the way full BEFORE you remove the exterior washer case. That way you can check for any leaks with water in the tub. Let me know what you fins. I hope this helps you.
May 04, 2009 | Washing Machines
The washer leaks from undrneath. It is below the two hoses. The paticular part is plastic and has a metal strap.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
May 03, 2009 | Washing Machines
Leaking washer
that washer has had alot of problems with the drain pump if yours has not been replaced with the new style pump motor it needs to be done. that the problem.
Nov 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
162 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
