Question about Dell Latitude D630 Notebook
The screen is still not responding
I have submitted a problem relating to my laptop's performance..but i guess it is not in the power options..because when i restart my laptop,the screen looks unusual and there is a line at the center..
if im not mistaken,the problem is in the video card..please help me...
  • P. Thomas
    P. Thomas May 11, 2010
    well..that is actually a video section of the motherboard...might require a full m/b replacement..got a warranty?
  • 458 Answers
To test if in fact it is your video card... try plugging an external monitor into your laptop... If You Get a clear screen No Lines or colors etc.... then it's not your video card..
Lines are common with A faulty circuit board on the display panel, So You Might Need To Replace LCD Display if the exernal test shows your video card is good...
Posted on Nov 21, 2008
How do you reset power management on the ibook g3
For most situations, a restart is sufficient. If the computer has stopped responding, try these steps, in order, until the computer responds:
  1. Force Quit (Option-Command-Escape)
  2. Restart (Control-Command-Power)
  3. Force Shut Down (press the power button for 10 seconds)
Only perform a PMU reset on the computer if none of the above steps resolved the situation.
Mar 26, 2014 | Apple iBook G3 Mac Notebook
My apple laptops login screen keeps going on and off on and off i cant login
Try resetting the SMC
Before Resetting the SMC Try each of the following steps in this order before you reset the SMC. Test the issue after completing each troubleshooting step to determine if the issue still occurs.
  1. Press Command + Option + Escape to force quit any application that is not responding.
  2. Put your Mac to sleep by choosing the Apple () menu from the upper-left menu bar and then choosing Sleep. Wake the computer after it has gone to sleep.
  3. Restart your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Restart.
  4. Shut down your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Shut Down.
If your Mac appears to be running normally but isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note: You will lose any unsaved work in any open applications.
For Mac portables experiencing issues related to the MagSafe power adapter and/or battery, try:
  1. Unplug the MagSafe power adapter from the Mac and the wall power socket for several seconds.
  2. Shutdown the Mac. Physically remove and re-insert the battery (if it's removable) and startup the Mac.
If the issue is still not resolved after following the troubleshooting items above, an SMC reset may be necessary.
After performing normal troubleshooting, these symptoms may indicate that an SMC reset may be necessary:
Fans
The computer's fans run at high speed although the computer is not experiencing heavy usage and is properly ventilated.
Lights
The keyboard backlight appears to behave incorrectly (on Mac computers that have this feature).
The Status Indicator Light (SIL) appears to behave incorrectly (on Mac computers that have an SIL).
Battery indicator lights, if present, appear to behave incorrectly (on portables that use non-removable batteries).
The display backlight doesn't respond correctly to ambient light changes on Mac computers that have this feature.
Power
The computer doesn't respond to the power button when pressed.
A portable Mac doesn't appear to respond properly when you close or open the lid.
The computer sleeps or shuts down unexpectedly.
The battery does not appear to be charging properly.
The MagSafe power adaptor LED doesn't appear to indicate the correct activity.
System Performance
The computer is running unusually slowly although it is not experiencing abnormally high CPU utilization.
Application icons may "bounce" in the Dock for an extended amount of time when launched.
Applications may not function correctly or may stop responding after being opened.
Video
A computer that supports target display mode does not switch into or out of target display mode as expected.
A computer that supports target display mode switches into or out of target display mode at unexpected times.
Oct 20, 2013 | Computers & Internet
Computer slow
not sure how a computer fault relates to gps device plus you appear to have submitted this more than once which doesn't help us.
if this problem relates to internet explorer then resetting it often helps. go into control panel and internet option, on the advanced tab, there's a button to reset.
there could also be a multitude of other problems causing the pc to be slow including hard drive nearly full, so you're probably better off taking it to a trusted pc repair shop to sort out.
Jul 19, 2013 | GPS
My LCD screen in LG R40 Labtop is a bit dim I cannot make it more bright.
Did you try changing your power settings. Go to your control panel in start menu and click that. Several icons should come up including power management. Click that and view power options. Change to a performance option. If that works try the next lesser option for performance. Find the best option for your needs between performance and battery life.
Jul 14, 2011 | Computers & Internet
When im on the computer the monitor shuts off a box appears saying power saving enabling monitor to shut down in a few seconds and then it restarts
Windows provides the following plans to help you manage your computer's power:
  • Balanced. Offers full performance when you need it and saves power during periods of inactivity. This is the best power plan for most people.
  • Power saver. Saves power by reducing system performance and screen brightness. This plan can help laptop users get the most from a single battery charge.
  • High performance. Maximizes screen brightness and might increase the computer's performance in some circumstances. This plan uses a lot more energy and will reduce the amount of time that a laptop battery lasts between charges.
    Note
    • High performance doesn't appear on the battery meter by default. To turn on High performance, open Power Options by clicking the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, and then clicking Control Panel. In the search box, type power options, and then click Power Options. Under Select a power plan, click Show additional plans, and then click High performance.
If these plans don't suit your needs, you can create your own power plan, using one of these plans as a starting point.
Feb 13, 2011 | Gateway 510 S PC Desktop
Dim lighting
You need to configure the power options.
Go to control panel and then click on power options.
Select advanced power options and there select the power mode as balanced or high performance.
Jul 20, 2010 | Acer Aspire 5100 Notebook
Do I need to specially configure my Travel Mate for "high performance mode"?
High Performance Mode is just a Power Configuration Preset Profile.
You can replace, add or edit Power Profiles by navigating to the Power Options menu in the control panel.
So No, You don't need to, but it's nice to edit it to your personal preferences.
Please RATE ME and submit a testimonial, if you would.
Thank You.
Mar 08, 2010 | Acer TravelMate 4072WLMi Notebook
Closing lid on notebook, Dell Inspiron 17, with OS Vista, causes screen to blank
I am guessing that you must have an external monitor attached and are attempting to close the notebook and use only the external monitor? If so, there is a setting in "Power Options" to allow you to close the lid and not go to stand-by.
*Go to your Control Panel (Start, Control Panel)
*Select Performance and Maintenance, then Power Options - or - if you are in Classic View, select Power Options
*Select the Advanced Tab
*Under the Power buttons section, select "Do nothing" from the drop-down for "When I close the lid of my portable computer"
Feb 21, 2010 | Dell Computers & Internet
Can i change experts
Please select the Safe Mode option. If you no longer have that option whenever you turn your computer on. you can press on F8 after power-on. If you are able to boot in Safe Mode, please try to do a system restore (Start-All Programs-Accessories-System Tools-System Restore). Choose a restore point with a date known to be a time when you never experienced this problem. If you are not able to boot using any of the advanced boot options, you will need to do a full system recovery (reinstall the OS). Hope this helps. Thank you.
Sep 22, 2008 | Toshiba Satellite M30X-S181ST Laptop
Dell Latitude D630 Notebook Logo
111 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
