Question about Microsoft Windows Vista Ultimate Edition
How to remove desktop.ini virus from windows vista
This virus is continuosly spreading in different files and corrupting these files.Its also eating memory.
  • freeaed Dec 05, 2008
    i have the same problem
    and there is autorun.ini also
  • 152 Answers
It is not a virus... it is some kind of error... goto filehippo.com and download a software called unlocker... you can remove desktop.ini using that....
Posted on Nov 21, 2008
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
What is desktop.ini is it a virus?
Since Desktop.ini is a Windows system file, you are probably seeing it because you have set Explorer to display hidden/system files. By reversing this setting, you can get rid of Desktop.ini.
  1. In any Windows Explorer window, click Tools → Folder Options…
  2. Click on the View tab.
  3. Check off the radio button next to “Do not show hidden files and folders”.
  4. Put a check in the box next to “Hide protected operating system files (recommended)”.
  5. Click OK.
Aug 25, 2009 | HP Pavilion dv4-1140go Laptop
Any file or document from word or excel.I have tried with other flash drive but same problem applied.
you may have a virus which is possibly resident on your flash drive.
Lately virus have been attacking flash drives and being spread to computer.
look in your drive for autorun.ini autorun.inf desktop.ini
if your see these files your infected and will need to take steps to get rid of the virus.
do a search for "flash drive virus" in gogole and see what comes up
Jun 05, 2009 | Dell Dimension 1100 PC Desktop
Bootup failure
Cause:
  1. Keyboard issue
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Dec 05, 2008 | Acer Aspire 3624WXCi Notebook
Error: windows root>\system32\ntoskrnl.exe
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
ACER DESKTOP COMPUTER
Related errors:
Cause:
  1. Keyboard issue
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
Desktop.ini problem
there is no problem frm that file
it's nor virus no anti-virus will not delete it
u can remove it frm un-locker
download it from www.filehippo.com
ur's kishore chowdary
+919441133420
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
108 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
