Question about Lexmark X5470 All-In-One InkJet Printer
States ''missing right ink cartridge''
Replaced my empty cartridge and every since I put in the new one, it reads "missing right ink cartridge". I have repeatedly taken it out and re-intstalled but still no luck. it's a brand new cartridge (color). Will still print black but no color. help, i could scream!!!!!
  • lcumberledge Nov 22, 2008
    Sammey, You Rock!!!!!
  • Anonymous Nov 26, 2008
    i have the same problem only mine says i am not using a origininal lexmark cartridge and therefore my warranty in not good.
    Problem Solver:
  • 17 Answers
Take the colour cartridge out, clean the printer were the ink goes through with a damp cloth then replace cartridge push down firmly about 5/6 times as though you are doing compressions
Posted on Nov 21, 2008
  • sammey Nov 24, 2008
    is it working ok lol kev -sammey
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    R 340 cartridges have remaining ink but printer
    just go to the process of ink cartridge replacement without actually putting in new ink cartridges, sometimes printers make read errors, just make sure ink cartridges are placed properly to position.
    Jan 17, 2010 | Epson Stylus Photo R340 InkJet Printer
    I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
    • Press the "Power" button to turn on your Lexmark
    • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
    • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
    • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
    Nov 19, 2009 | Office Equipment & Supplies
    My refilled canon ip1600 ink jets are reading as empty
    To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
    Jun 09, 2009 | Canon PIXMA iP1600 Printer
    Printer cannot find new black cartridge. Left cartridge missing.
    The electronics are bad on your compatible and your printer can't recognize it's there. Return this cartridge and get your money back. The next cartridge you buy, ask if the electronics have been tested to be functional. I recommend refils from Cartridge World or Office Depot.
    Apr 05, 2009 | Lexmark X4530 InkJet Printer
    Problem with replacing color ink cart. #5
    Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
    Mar 31, 2009 | Lexmark X2600 InkJet Printer
    Ink was low I put a new cartridge in still says low wont print.
    Hi
    try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
    Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
    New ink cartridge for Kodak Easy Share 5300 will not work
    The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
    So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
    Kodak AiO 5300 Firmware
    Then sadly you have to go get another new ink tank and install it.
    If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
    I hope this helps
    Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
    My kodak 5300 will not accept the new ink cartridges
    Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Lexmark X5470 All-In-One InkJet Printer Logo
    489 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
