Question about Asrock 775VM800 Motherboard
Conflict with the display and the PC display will not come out
The pc was installed with an os together with the monitor when 15 computers were transported to other place the monitors were interchange. The display now of the PC's will not come out. The video card are not functioning well. sometimes it turns sometimes not.
Does the monitor inter change affected the display of the monitors?
Thank you please help me on this....
my product motherboard is ASROCK and video card are vvidia editions
  • 189 Answers
I think there is no effect even if the monitor was interchange, maybe during the travel the video card was loosen, have it check. Check also the pins of the monitor cable, if some are broken.
Thanks
Posted on Nov 21, 2008
X322bv powers on but does not show screen
It could be that your PC is having video issues booting. Find another monitor and see if it displays correctly. If it does, your original monitor is defective. If it doesn't, your PC boot has video issues (bad drivers, recently installed software causing conflicts with video card, etc.)
Sep 01, 2014 | Sceptre X322BV HD 32 inch Class Television...
When my computer starts its display driver does not work but after some time when windows starts it works correctly
Possible that PC is hanging up as there is fault on the OS ( operating system) . So open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Jul 26, 2011 | Sampo PD-70 15" Flat Panel LCD Monitor
When I turn on the monitor, I get an error message: "Warning PC entering power saving mode", then it turns off.
Unplug your dekstop from the electricity then press and hold the power button on your desktop for couple minutes with out no power cable attached to it then let go of the power button then connect your desktop back to electrical outlet and press power button once that should give you display once it turns back on you can go into your power saving options and turn off power saver mode as its conflicting with your LCD sometimes this can occur if you have Norton antivirus installed
if after doing the power drain and still get same message then you can try using a different monitor if you have one for a test.
this issue is not with your monitor but with the PC has been stuck in sleep mode but the power drain should solve your problem.
Mar 01, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
My PC's startup and game screens too far left
There may have been a software driver for your monitor for windows Vista to set the correct parameters
- here’s what I found on Microsoft’s site but only for Windows 7
https://support.microsoft.com/en-us/help/14108/windows-7-change-screen-resolution
Here’s some info about drivers for monitors on windows vista and 7 :
https://uk.answers.acer.com/app/answers/detail/a_id/4085/~/monitor-driver-installation-in-windows-vista-and-windows-7
Feb 06, 2018 | Hanns.G Corporation HW173D Monitor
Monitor flickers sometimes when starting pc and won't come on.
if it is an older tube monitor - it seems it is at it's last breaths or the graphic adapter may be malfunctioning.
- please ensure all the cables( the internal ones, too) are attached properly,
-appropriate drivers fitting your OS are installed
- that there is no internal hardware conflict (IRQ conflict), please see: settings/hardware/device-manager for details
- try to hook up another monitor to double-check it is really the moni and not the graphics card!
if the issue occurs only in the original combinaton of old moni and PC, do consider to get a newer one.
another hint for an old moni is a slightly colour mismatch (maybe it has come to the red side?)
happy shopping
Aug 04, 2009 | Computers & Internet
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
I get a an error after installing my nivida graphics card to use dual monitors error: invalid display settings currently selected graphics display driver can not be used. It was written for a...
In that case, your pc might have a conflict.. it maybe the version of the display driver.. perform a clean install on the video card driver by doing this.. assuming that your PC's OS is WinXP..
1. On your desktop right click the icon My Computer and click properties..
2. On the System properties click Hardware then click Device Manager..
3. On the device manager window look for the display adapters then click the + sign on the left side..
then it will shows the display adapter you have on your pc..
4. Right click your display adapter then click uninstall.. from there your pc will remove the display adapter you select then it will ask you to reboot..
5. Now were assuming at this time that your pc has been rebooted.. Browse your Display driver and then install..
hope this will help..
Dec 05, 2008 | Computers & Internet
Asrock 775VM800 Motherboard Logo
66 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
