Printer won't come on. checked connections. no prior probblems. ink is low
  • 10,515 Answers
Steps....
CHECK UR PRINTER CABLE.....
Make sure your printer cable is securely connected between the PC and printer. The cable should be less than 10 feet (3 m) long.
Step2Check for any bent pins on the printer cable. If you find any, straighten them with needle-nose pliers. Step3If you aren't sure about your cable, try swapping it with one from another printer. If the printer suddenly starts working, you know that your original cable is defective. Step4If you're replacing a parallel cable, be sure to get an IEEE 1284 (look at the packaging label or ask a salesperson). Older cables often won't work in newer printers, even though they might look like they should. UPDATE AND RELOAD UR DRIVERS 1Check the Web site for your printer's manufacturer and download the latest version of the driver software for your printer. Step2Open the Printers folder through the Start, Settings menus. Step3Right-click on the icon for your printer. Step4Choose Delete. Step5Double-click on the Add Printer icon in the Printers folder. Step6Follow the Add Printer wizard directions to reinstall the driver software VERIFY PRINTER PROPERTIES
Open the Printers folder through the Start, Settings menus. Step2Right-click on the icon for your printer, then select Properties. Step3Verify that all of your printer's properties are configured as recommended by your printer's manufacturer. You can look up these guidelines in the documentation that came with your printer or, if you've misplaced it, on the manufacturer's Web site CHECK UR PARALLEL PORT SETTING Right-click on My Computer and select Properties (in Windows 2000, you'll need to then click on the Hardware tab). Step2Go to Device Manager. Step3Double-click on Ports (COM and LPT). Step4Double-click on Printer Port (LPT1) and select the Resources tab. Step5Check the "Conflicting device list" box for an interrupt request line (IRQ) conflict. No other device should be using the same IRQ as the printer port. Step6If you find a conflict, disable the offending device or assign it a new IRQ. To disable a device, find it in Device Manager, open its Properties dialog box, select the General tab and check "Disable in this hardware profile." REMOVE TEMPORARY FILES AND SOPPL FILES Windows must be off, so restart your computer to a DOS command prompt. In Windows 95, press F8 when you see the words "Starting Windows 95" appear, then choose Safe Mode Command Prompt Only from the Startup menu. Step2In Windows 98, restart your computer, press and hold down the Control key after your computer completes the Power-On Self- Test, then choose Safe Mode Command Prompt Only from the Startup menu. Step3At the command prompt, type the word "set," then press Enter. Step4Write down the location (the DOS file path) of the TEMP variable. Step5Change your directory to the folder you noted in step 4. For example, if TEMP is set to C:WindowsTemp, you'll type "cd windowstemp" and then press Enter. Step6Once you're in the Temp folder, you can delete any temporary files that might be there, by typing "del *.tmp" and then pressing Enter. Don't delete these files while Windows is running, because Windows 95/98 or a Windows-based program might be using one of them. Step7Type "cd windowsspoolprinters" and then press Enter to switch to the spool folder. Step8Delete any spool files you find here by typing "del *.spl" and then pressing Enter. .... Thnx.
Posted on Nov 21, 2008
    Brigadier General:
  • 6,966 Answers
Depending on the brand and model of the printer, it is power supply related. Some printers have external power supply that supply dual voltage as those used by some HP. Still others have built-in power supply. Most designs would have a fuse. However, to gain access to the fuse, the adapter or the printer unit has to be opened up. More often, the fuse is always located right after the AC cord.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Master:
  • 505 Answers
1. Try a different power outlet
2. Change the power cable
Ink level has nothing to do with printer not turning on.
Also check the power button. If you still have the problem, the power board needs to be repaired / checked for any loose connection.
Thanks
  • 734 Answers
Please give details of model number..
  • futureloginn
    futureloginn Nov 21, 2008
    also do-- uninstall tthe printer driver and again reinstall.
    Thanks
Red waening light keeps flashing and printer won't
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 21, 2011 | Epson Office Equipment & Supplies
My epson DX8400 won't print yellow at all, green prints as blue, red prints pink on certain documents i've created. I have printed an email off today which printed all the colours perfectly??
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Aug 22, 2011 | Office Equipment & Supplies
My i550 won't print When I turn it on there's a short grinding noise Then there's a short green flash, then short orange, short green, short orange then longer green This cycle then keeps...
Aug 18, 2011 | Canon BubbleJet i550 InkJet Printer
Won't recognize print cartridges, says it is missing or damaged
Aug 12, 2011 | Office Equipment & Supplies
Installing new colour cartridge but says alignment failed and won't print new colour. If replace depleted cartridge still get some colour coming through. Have tried cleaning etc but still get same...
are u sure that the color cartridge is compatible with ur printer ??
if ya ... maybe the cables in the printer are broken or smthn like that
if no ... be sure to buy the same cartridge code founded in ur printer
i hope i helped :D
Jul 08, 2011 | HP Photosmart C4180 All-In-One InkJet...
There is a light flashing on the one switch on my Hp Deskjet d2360 and it won't print. I think it might be a mechanical problem, but I can't see anything wrong..
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 08, 2011 | HP Office Equipment & Supplies
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Priter probblems
First, try removing and installing inks again, after that try updating FIRMWARE. Use this site www.kodak.com/go/downloads
Oct 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
13 people viewed this question
k24674
jasbo
jasbo
