Connecting dvd to tv
I've connect the dvd to the tv but there is no sound and only a scrambled rolling picture
  • Anonymous Nov 22, 2008
    Ihave no sound and the dvd remote control interacts with the tv by cutting the tv off. I have a new vizio hdtv
  • mkizenko Dec 22, 2008
    I moved my TV & Daewoo DV6T844B DVD Player / VCR Combo within the same apartment...Cable goes into "Antenna In" RF goes to cable box. Player works but no picture appears on TV
    President:
  • 2,992 Answers
It sounds like you may have a connecting cable problem, although it could be the player itself is bad. Make sure you haven't gotten the video and audio connections switched around if you are hooking the player to the TV that way. If you are using an RF connection to the TV's antenna input, be sure the TV is on the right channel (3 or 4) to match the player setting.
Posted on Nov 21, 2008
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Picture rolls when playing disc
Check all the connections on the back of player and tv.
does not sound to hopeful.
have you tried another player on the tv and what is the result ?
Feb 10, 2011 | Protron PD-007 DVD Player
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Picture is scrambled when first turned on
connect a dvd up,and see if you still have the problem with the dvd.i thank you have a proplem with your cable or antenna.
Aug 19, 2009 | Toshiba Televison & Video
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Hooking up GPX D1816
it really doesnt matter what color the cables are as long as the one from video out on the dvd player is going to video in on the tv then the same for the sound.yellow is generally video and red would be your sound
Aug 03, 2008 | GPX D1816 DVD Player
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
MDVD-6838 and Panasonic Plasma TV incompatibilty
1 click SETUP(left just below the four arrow w/ enter button in the middle)
2 click DISPLAY
set tv system to AUTO
tv image to 16:9 WIDESCREEN
video setup (depend on the connection)
s video or RGB
Nov 08, 2007 | Wanlida Group MDVD-6838 DVD Player
Recording from my vcr to the dvd hardrive
It may be that the tape you are trying to record from is copy-protected. You will then get a "scrambled" picture
Nov 04, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
