Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Model JGBP35BEA9BB
The oven will not come on in the GE gas stove that we have. The house is only a few years old and the appliance is like new. The oven has been working up until yesterday but now the stove top burners are fine but the oven will not start heating up. The electronic control panel will allow you to select Bake and select a temperature but when you hit the keypad to start nothing happens, no clicking, no gradual increase of the temperature, etc. The GE manual doesn't give you much other than calling their service guys. I read something on the GE site that discussed "re-setting" of the electronics by unplugging the stove and plugging it back in. Is this adviseable and could it hurt anything else? I presume this could also be an oven ignitor problem?? Thanks for the help! __ Larry
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
I turn on the stove and it lights and then it dies, then it won't turn on anymore. The other pilots don't turn on either. It worked this morning and when I came home this is the problem I encountered.
Ok, now that I know it's natural gas, what I would like for you to do is fire off the other gas appliances (furnace, water heater, etc) you have in the house to see if you having a similar problem with them as well. If so, you may may a regulator problem (at the meter) and will need to contact your gas co to replace or repair their equipment. If not, and the problem is isolated to the stove only, then you may have a defective appliance regulator, which supplies gas to all the burners on the stovetop and the oven. How old is the stove? Is it still under warranty? If so, you can call G.E. and have them service the stove for free.
Jun 03, 2010 | GE Spectra JBP78 Electric Kitchen Range
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I just moved into a house and the GE oven appears to be approx. 16 years old. The oven will not cook between 300 and 450 degrees. It will either undercook or burn the food.
16 Years old? Sounds like you need to buy a new one. One thing you don't want to do now is to start putting lots of money into an old appliance.
Oct 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE oven ignitor replaced, gas turns on but no flame
Yeah, blowing up the house is never a good way to replace an appliance :)
Try contacting GE at: http://www.geappliances.com/service_and_support/contact/form_service.htm. It should be free and they'll be able to help you narrow down what's going on.
Alternately, new GE ranges start at a little over $400 at Home Depot... You certainly have to appreciate keeping a good appliance going, but if it starts nickel & dimeing you, it may be that range's time to go.
May 24, 2009 | General Electric Stove/Oven/Range Chrome...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
128 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
