I have looked at the menu options on monitor There is a speaker ? showing sound waves adjustable mumbers, at minute 28 There is a speaker ? with a X in front of it option is ON or OFF Nothing seems to do anything. Help
Comments:
Nov 21, 2008
- HI
Many thanks.
I have upended the monitor (for 1st time) and found a green and a blue jack hole. Under frame of monitor (model 821A) I had only looked at base support and there was nothing there, I was actually covering these two connection points with hands holding monitor up.
I will get a connection cable and join ti computer green to green.
So many thanks, do I have to do anything else to make work ? anything on menu buttons on monitor ?
Hey...Dude,
To check if there a built-in speakers... look under the monitor and look for a audio jack usually located next to the VGA and power connections. If you got one, then you need a audio cable to connected to from your monitor to your pc audio output jack.
Comments:
Nov 21, 2008
- hEY...John,
Well, all you need it plugged the audio cable to each end of the jacks. Then open your on screen display on your monitor and set the volume control to your desire settings. And that it...you can listens or watched your favorite movies...but built-in speakers only came 2 watts, doesn't have a good quality sound. Anyways, have fun!
I have lost my adaptor of my 173P.Can i buy a compatible one? Also the problem is it's 14vdc,but i...
(More)
I have lost my adaptor of my 173P.Can i buy a compatible one? Also the problem is it's 14vdc,but i do not know the amp required.
my monitor is HP w17e. it was wou king fine then we moved and now the speakers are not working, they...
(More)
my monitor is HP w17e. it was wou king fine then we moved and now the speakers are not working, they are built in
I just got an acer p235h monitor it is currently hdmi and my second monitor is vgi, the acer display...
(More)
I just got an acer p235h monitor it is currently hdmi and my second monitor is vgi, the acer display does not stretch across the entire screen
not able to turn it on. for no apparent reason the screen was black after setting overnight. The...
(More)
not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top would be comming up. The screen remained black. desided to turn the monitor off and back on again. pushing the on/off switch the pilot light went out. Pressing the switch again did not power up the monitor. It did not even lumate the pilot light. Have tried another power cord with no success. Name plate shows unit was made Jan 2008. Is there a fuse or reset botton?
