Question about Sony Hands-Free Earset for Ericsson K750 D750 W800 Headset
Joystick not working
After extensive usage, the joystick on my phone is no longer responding very well, the click option still works, it's just the up, down, left and right motions that dont. I've read that this is a general problem with Sony phones, however, does anyone know how I may be able to fix it? Thanks in advance Stephen
I find pushing down on the stick after you've pushed it one way or the other helps... Damn annoying, I've had 3 Sony phones, all suffer from this
Posted on Apr 25, 2007
Hi Stephen I also have a sony ericsson (D750i) with joystick problems. As i suspect it's dust clogging the contact points beneath, what i do to clear it is use a fine old toothbrush to brush around the opening of the joystick and it also helps if you blow hard into that area...i imagine a compressed airline would be ideal. Iknow it seems a bit primitive doing this to such a technologically advanced phone but it does work....even though it is only for a couple days. As i've got about 4-5 months left on my present 18 contract, my next step is to see if one of those mobile phone "hospital" shops can open it up and give it a good clean and maybe sort a new facsia for it. Anyway, i'm not sure i'll be going for a sony next time....unless they can sort this problem. Good Luck Andrew
Posted on Feb 15, 2007
Hi! I'm just going to ask regarding the joystick of my n73. I'm having problem with it, since I can't use it already. It seems like it is already pushed, like if I'm using it, I can't...
Hello there,
The problem with the phone is that the joystick is weak and is not sitting anymore on the phones board, it need to be replaced. That is what you have to do, they sell the joystick in stores or you can get a phone that no longer works and use the joystick.
You will have to take out the joystick by disassembling the phone, and reaching for it,then replace it with new one. That works all the time,if not the phone will be out of controll as the navigation button is what shows its functions.
Hope this helps
Goodluck
Elect_Comp
Aug 10, 2011 | Nokia N73 Cellular Phone
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
Cursor up and down did not move
Is it the directional buttons or the joystick that isn't responding, and does it not respond with everything or just certain games or menus? First thing you could try that would be the easiest is with the system off and the battery out put some rubbing alcohol or windex into the buttons or joystick. Not a lot just enough to get it into and under the contacts. After doing this work the buttons a bit or spin the joystick around to try to loosen any dirt build up. Then use an air compressor or a can of air and spray the buttons or joystick to disperse the fluid so it can dry. Let it set for about a half an hour or longer to dry and give it a try. If this doesn't work you may have to take it apart to replace either the joystick or the directional pad strip. You can find easy tutorials on youtube for disassembling it.
Good luck and happy gaming!
William
Jan 25, 2011 | Sony PSP (Piano Black)
My 320i joystick doesnt work anymore!
Is your mobile under warranty ?
If yes then you can ask for your operator to change the joystick in your mobile .
Joystick button is damaged only option is it to change it .
Nothing can be done other than changing it .
Dec 06, 2009 | Sony Ericsson K320i Cellular Phone
I want to know will a Logitech Attack 3 Joystick work on need for speed underground 2 or can you even use joysticks fos racing games
ya the joystick will work you can use it because am also having the same am using it , its perfect but you have change control options in the game to joystick control and also if you want you can the options as you like, but this kind of joy is mainly used for flight running games but it also works for all joypad control games too.
Oct 22, 2009 | Logitech Attack 3 Joystick
Wingman extreme digital 3d not working.
you dont get any responds or recognition from windows other then in the deivce manager. it is working on the older joystick system so only the game has the capability of recognizing and making the button assignment if it supports joystick drivers.
in case your using driver that are too new here are the drivers for 15 pin logitech devices.
ftp://ftp.logitech.com/pub/techsupport/joystick/lgs460enu.exe
Jul 20, 2009 | Logitech WingMan Extreme Digital 3D...
My sony erricson k750i phone's joystick is not responding
you have to clean the joystick by using contact cleaner. open the cover of joy stick, there is a switch inside it having a metallic cover. use contact cleaner and let it for few minutes.
DONT FORGET TO REMOVE LCD FIRST. it can be damage with contact cleaner. i had a bad experience of it.
btw it happens with sony ericsson phone joystick problem.if joystick problem still persist u have to show it to sony ericsson repair centre or your warranty center of mobile.and u can also use the keys your keypad keys for up down left right.
thankyou.
May 06, 2009 | Sony Ericsson K510i Cellular Phone
Joystick not working (gets detected but keys dont respond)
hi,
update the drivers for your joy stick and yourAsus M2A-VM motherboard
at the link below.
www.support.asus.com
Nov 27, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Keypad and joytick problem
Hi
First of all tell me model of cellphone, so that it i can give u proper solution.
bye
sr99mobiles@yahoo.co.in
Nov 26, 2007 | Sony Ericsson K800i Cellular Phone
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
Radio Communications Logo
66 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Bobby G
Bobby G
Rob Beech
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
