Question about Intel D101GGC Motherboard
Buzzer sound from intel d101ggc motherboard
The motherboard is making a buzzer sound at regular intervals. is it indicating something? moreover the pc speed has gone slow drastically and it hangs frequently now. please solve my problem.
  • 207 Answers
Check the power leads to your CPU's heatsink fan. Often times when I hear a "Buzzing" sound and NOT a beeping sound from inside the case, its because fan leads have gotten too close to fan blades. If this is the case and your losing speed on your fan or it is stopped altogether, then your CPU will overheat and cause your PC to freeze/hang, and/or reboot/Shutdown. If it happens too much you may even fry your CPU.
If you do find a fan with leads near a fans blades. Inspect the leads carefully for damage. Try running the PC and see if the fan MOVES. If the leads are damaged or if the fan does NOT move. You need to replace this fan. Go to your local electronics store and purchase a new one and install it.
IF its a CPU fan, you'll need to tell them if its for an Intel or AMD CPU or one of the other chips should you happen to have one of the other 2% of CPU's out there.
If it is a case fan you will need to take it out of the system and take it to the store with you to "Size" it against the new one (There are several different sizes) Any of the fans should be attached with 4 screws 1 at each of their corners (Save these screws, as most new fans don't come with replacements for these)
I hope this is your problem, IF NOT message me back here and I will walk you through checking the NEXT possibility.
Posted on Nov 21, 2008
  • 1,073 Answers
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
My sound driver was deleted last time. iwant a sound driver for my intel mother board my desktop board no. is D101GGC
Intel has an excelent support website with most all drivers you might want.
Try the following site:
Oct 09, 2010 | Intel D101GGC Motherboard
Audio problem in my pc
i need a driver sound for vt1723
Apr 07, 2009 | Intel D101GGC Motherboard
Sound driver problem
There you go!
Select "latest drivers"
You will find the drivers you need there.
Good luck
Nov 26, 2008 | Intel D101GGC Motherboard
Intel d101ggc making buzzer sound at equal intervals and then pc hangs.
OK this buzz is suppose to be a beep.
The device you described is called apezo electric speaker and is suppose to beep a post code to help define a problem.
If it's buzzing and not beeping there is either a fault with the piezo or the motherboard is not receiving the amount of power it needs to properly drive the speaker.
OK back to the post code. The patern is important it should be a series of long and short beeps. The fact that it is buzzing and not beeping may make it difficult to determine the difference between long and short beeeps.
Try your best to hear a pattern in it. Whether its constant beeps or 2 short 1 long or any other discernable variation please post back the number of beeps and if there is a long or short pattern.
please post back here
Nov 21, 2008 | Intel D101GGC Motherboard
Buzzer sound from motherboard spkr
Hi kuldeep11203, your Intel D101GGC board uses the Award bios.
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
Good luck kuldeep11203!
Need sound drivers
download intel mother board drivers
Nov 22, 2007 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
