posted by Tencate on Jan 03, 2007
I am borrowing a Pali Donna Crib and the previous child chewed on the top of the railing. I would like to paint the crib, but I would also like to know if I can purchase a piece that can go on the rails to avoid this from happening in the future.
Comment by Tencate, posted on Jan 03, 2007
I am hoping someone knows where I can purchase a clear piece that can go on the top of the rail to avoid my child from chewing on the crib.
Solution #1
posted on Mar 28, 2007
A piece of plastic hosepipe, sliced down the side might do the job - glue it on with a small amount of silicon sealant (don't worry you can get it off if you need to).
The other way would be to wrap something around the rail in the style of bandages - use some clear PVC (Vinyl) or similar cut into strips. you could use adhesive pvc tape, but the glue tends to work it's way out and gets sticky and messy.
If you are struggling to see what I mean then have a look at a few pictures of sailing yachts in harbour (google image search works well) - you will see every different possible way of covering up a railing.
Hope this helps, I found no sign of a purpose designed piece for this crib online :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Cribs and Bassinets problems?
Repair Service
Find Crib and Bassinet Repairman Near You:
