Question about Cosco Alpha Omega Elite 5-Point 22-155
LATCH Attached? When I tried to install the LATCH belt (rear facing) it won't stretch far enough because it is stitched to a piece of nylon which is rivited to the plastic in the center back of the carseat. The instruction manual does not show the latch belt secured to the carseat at all and I was wondering if it would be ok to cut the belt loose. There is nothing in the manual about the LATCH belt being permanently attached to the carseat. It shows it loose for both the forward and rear facing installations. Thanks, David
  • Anonymous Feb 10, 2009
    The
    The Latch Belt doesn't reach the hooks in my car when the carseat is rear facing. I'm not sure how to fix the problem?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Posted on Apr 26, 2009
    Scholar:
  • 90 Answers
Don't cut it off. If it won't reach and you can't adjust the length of it, just use the lap belt until you child can face forward. I didn't use the LATCH system when my son was younger because my car didn't have it and he was fine. the seat was secure enough with the lap belt only.
Hope this helps.
Posted on Jan 02, 2009
Elna 2005 I don't have the manual. Which setting is for the stretch stitch?
A special stretch stitch is not required to sew stretchy fabric. All one needs is a zig-zag that is wide enough and close together enough to allow the fabric to stretch without breaking the stitching thread. (Test it on a piece of scrap fabric you are using, give it a good tug and see if the thread breaks.)
NOTE: be sure to use a ball-point needle. A sharp needle will tend to cut the fabric threads and your stretch fabric will eventually develop holes and runs commonly found in knits.
There doesn't appear to be a manual for your machine, however, you can usually find a manual close to your machine model and the instructions will be similar enough to suffice. Perhaps you will find one with instructions for sewing stretch fabric:
ELNA Other manuals
Jan 10, 2016 | Elna Sewing Machines
Door latch stays down and will not allow the door to close
sound like the litle robe on the door latch has stretched
Feb 05, 2014 | Whirlpool Dishwashers
Storage bin under rear seat stuck
try pushing down first and holding it down while turning the latch. If it opens then spray it with some WD 40. If you can't push down hard enough then get one of you cute little curtain climbers to stand or even jump on it while you turn the knob. I hope i/m the winner. Picture me smiling with a big grin on my face. LOL I won I won. I helped someone. Keep me happy and let me know if I did. Good Luck, Raz
Apr 17, 2010 | 2004 Mercury Mountaineer
How do I overlock stretch fabrics so the stitches won't break when the fabric stretches?
I suggest also setting the stitch length to about 2 (very close together). When the stitch is shorter, it seems to be able to give a little more. I also use woolly nylon, but I still had the problem (especially when hemming). This is how I solved my problem....
Jan 24, 2010 | Janome MyLock 634D Mechanical Sewing...
Latch belt too short
Looked at the owner's manual of my car and realized where I needed to hook the latch belt hook strap. I was trying to hook it to the wrong thing. Car seat works great now!
Nov 21, 2009 | Safety 1st Baby Gear
How to install power window motor in a 1997 Taurus
YOUR OLD MOTOR SHOULD HAVE RIVITS HOLDING THE UNIT TO THE DOOR. YOU MUST DRILL OUT THE RIVITS JUST TO THE MOTOR AND REMOVE. IF THE NEW MOTOR DID NOT COME WITH BOLTS YOU WILL HAVE TO BUY THEMFROM ANY HARDWARE STORE.SHOULD BE 1/4-20S OR 5/16-20 BOLTS JUST LONG ENOUGH TO LEAVE ROOM FOR THE NUTSTO LONG CAN CAUSE PROBLEMS, ALSO BUY LOCK NUTS WITH NYLON LOCKS SO THEY WON'T VIBRATE LOOSE. GETTING THE DOOR PANEL OFF SHOULD BE EASY, REMOVE HANDLES AND SCREWS AROUND DOOR POCKET CHECK CAREFULLY FOR HIDDEN SCREWS
GENTLY PRY THE DOOR PANEL FROM BETWEEN THE METAL DOOR AND THE PANEL, SHOULD BE 6-8 PLASTIC DOOR GROMMETS HOLDING THE PANEL AFTER ALL ARE LOOSE GENTLY PULL THE PANEL OUT AT THE BOTTOM AND RAISE THE PANEL NU TO RELEASE IT FROM THE TOP WINDOW AREA. YOU SHOULD BE ABLE TO UNPLUG THE WINDOW MOTOR CONTROLS AT THIS POINT AND SET PANEL OFF TO SIDE AND START WITH THE RIVITS. WHEN YOU GET THIS FAR THE WINDOW SHOULD BE IN THE UP POSISTION EITHER SUPPORT THE WINDOW FROM INSID THE DOOR AREA WITH A PIECE OF WOOD OR SOMETHING SO IT WON'T FALL AND BREAK. I DAVE USED DUCT TAPE FOR THIS AND WORK WELL ALSO BUT USE ENOUGH TO TAPE FROM THE OUTSIDE TO THE INSIDE ACROSS THE TOP OF THE DOOR
LET ME KNOW HOW THINGS GO
Aug 11, 2009 | 1997 Ford Taurus
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
How do you install the car seat for rear facing?
Hey Just posting this for future reference for other people since I see that you posted over a month ago :) ..
To install the car seat in rear facing I used the latch system. (you can use the latch system if your vehicle has latches..they are tiny metal bars in between the seats)
First of all with this dumb car seat I found out that the latch system was not in the proper place so if you find that yours is not where the diagram shows (in the manual) then you'll have to take off the seat cover and manually put them in their place. Then go ahead and clip onto the latches in the rear facing position. If the car seat is too far forward then inline the seat. If the car seat is still not leaning far enough back to be level with the ground (there should be two level marks on the top/side of the car seat) place a rolled towel (or roll a 2x4 in a rolled towel like i did) then clip onto the latches. Hope this helps someone.
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Insuficient clearance for caset to install
There is a lock on the door mechanism. Unless the belts are good, the machine will not recycle to move the heads down far enough for the tape to be removed, so the door is interlocked to prevent damage.
Take the case off and push the door release and watch where the release lever hits a small nylon piece. You can pushit down with a pencil or screwdriver and the door will open. This white nylon piece will stay locked down if the blets are good and do not slip. They put the door latch in park allowing the tape to be inserted or removed.
Try to treat the belts with rejuvenator CaiKleen™ RBR Let them sit a while to get rejuvenated enough to not slip and the problem should be solved.
Sep 26, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Cosco Alpha Omega Elite 5-Point 22-155 Logo
494 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
